Old 09-26-2020, 09:59 AM   #1
Standing Elk
Default Interior tacks
How do you hide the heads of the tacks when installing the strips above and to the rear of the doors on a 30 coupe. I need to install new wind lace and will need to remove these pieces to do so. Thanks
Standing Elk is offline   Reply With Quote
Old 09-26-2020, 11:46 AM   #2
duke36
Default Re: Interior tacks
Suggest using brads with the smallest heads possible. Drive only far enough to set the panel below the material surface, then pull material out above head with a needle.
