09-24-2020, 06:55 AM | #1 |
1938 Firestone whitewall tire pressure
Our 1938 Deluxe wagon has Firestone whitewalls; however, I cannot find the correct (or reasonably correct) inflation pressure. Would appreciate any guidance. Thank you
09-24-2020, 08:53 AM | #2 |
Re: 1938 Firestone whitewall tire pressure
Back when I worked at a gas station, in the bias ply days, we used 28-32 psi for everything except truck tires, Volkswagens and Corvairs.
09-24-2020, 09:34 AM | #3 |
Thank you
09-24-2020, 09:41 AM | #4 |
You haven't told us if you have radials or bias plys. 32 is a decent general number for radials. Bias plys need less. Previously, I had a set of Firestone wide white bias plys on my '51 Ford. The factory sticker on the inside of the glovebox door on my very original car says 24 front and 21 rear. I know, it surprised me too.
09-24-2020, 10:01 AM | #5 |
Here's what the owners manual says. In 1951, the "DeLuxe" (base) models came with 6.00 X 16 tires. Note the significantly higher pressure they call for. It's on the bottom of the right hand page. For those of you who don't want to strain your eyes or neck, it says :
...Size...Front Rear 6.70 X 15 24 21 6.00 X 16 28 25 7.10 X 15 25 30 (I believe the 7.10 X 15's were used on station wagons, thus the higher rear pressure. Last edited by tubman; 09-24-2020 at 10:07 AM. |
09-24-2020, 10:13 AM | #6 |
09-24-2020, 06:49 PM | #7 |
On my daily driven 35 pickup the fronts 5.50x16 I ran at 35, the rears 7.50x16 at 32. The front tyres are still in great condition after 6 years and would have years more left in them.
"Came too close to dying to stop living now!" |
09-24-2020, 07:51 PM | #8 |
Again; radials or bias-ply? It does make a difference.
I am quite surprised that many of you suggest deviating from what Ford Motor Company recommends by a substantial amount. And that you seem to think there is no difference between radials an bias-plys. Last edited by tubman; 09-24-2020 at 08:17 PM. |
09-24-2020, 08:18 PM | #9 |
My firestone deluxe champion bias Ply whitewalls 6.50-16 say max 32 psi @ max load 1580lbs.
09-24-2020, 08:55 PM | #10 | |
While the car companies knew exactly which combination of automobile and tires would be in use, the tire companies had no idea how their tires were to be used. |
09-24-2020, 09:05 PM | #11 |
Bias ply, my apologies; sounds like < 32 psi is the way to go. The genesis of the question has to do with seeing if correct inflation improves the sometimes “vague” tracking through corners or if this is just a fact of life with bias ply construction. I like the look of the Firestone bias whitewalls, but don’t want to add sway bars to an otherwise unmolested car.
09-24-2020, 09:36 PM | #12 |
My 1938 ford reference book says to keep tires inflated to 30psi. 1932-1948 Ford maintenance manual has spread sheet for specific psi for specific tire size. Hopefully the pics are clear enough to read.
Not Sure if I'd run 32psi as that is max rating. Personally I run 30 psi all around. Although the maintenance manual specifies 28 psi for my tire size 6.50-16-4. The amount of ply's play a part as well as size. |
09-24-2020, 10:53 PM | #13 |
Tires, like most everything else, evolve and have improved over the years, so
the recommendations listed in your old car handbook, were for the tires made at that time. Many of the new radials have a Max pressure of 44 and even 51#'s. Look at the recommendations that the tire manufacture puts right on the tire, and I generally run a few pounds less than the Max listed on the tire. Use some common sense on how much less, generally 4 to 8#'s less, depending on the weight of your car, and a couple #'s less in the rear than the front. Here is an article about under inflated tires. Driving on under-inflated tires is dangerous. According to the National Highway Traffic Safety Administration, almost 1/3 of passenger cars, light trucks and SUVs are being driven with at least one under-inflated tire. Under-inflation is one of the leading causes of tire failure. If tire pressure is too low, too much of the tire’s surface area touches the road, which increases friction. Increased friction can cause the tires to overheat, which can lead to premature wear, tread separation and blowouts. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
09-25-2020, 05:33 AM | #14 |
This is incredibly helpful, thank you all
09-25-2020, 11:14 AM | #15 | |
Ditto.. I just responded to the same question (s) about tire pressure on '53 model year Chrysler. The owner of the vehicle was running 24 psi on bias ply tires, had questions why the car handled so poorly. When I was in my late teens I went through a Standard Oil, Inc training school in order to go to work for the company.. Standard Oil really stressed tire safety and correct tire pressure. The majority of the responses on the Mopar forum told the man to follow the factory manual which stated 24 psi., with no allowance for weight speed, etc., of course that is the difference between old school and modern technology.
Bill.... 36 5 win cpe |
09-25-2020, 01:10 PM | #16 |
"correct inflation improves the sometimes “vague” tracking through corners"
How old are the tires?? Makes a difference. JMO Paul in CT |
09-25-2020, 01:16 PM | #17 |
Probably 12-15 years old, but no evidence of dry rot
09-25-2020, 04:30 PM | #18 |
No but I bet the sidewalls are very stiff. JMO I've got Remington's (15") that are old but still ride nice on the highway or around town (G-78 & L-78).
Paul in CT |
09-25-2020, 04:50 PM | #19 |
Hi Everyone. Jacques1960, you didn't ask for this kind of advice, but I'd put tires way up high on your 'to-get' list if you're thinking of driving any distance at all.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
09-25-2020, 06:41 PM | #20 |
