Old 03-12-2020, 10:10 AM   #1
cederholm
cederholm's Avatar
Default windshield replacement - how to??
Hi all,
The bottom of my windshield frame was rotted and badly repaired. I've tracked down a replacement with safety glass installed.
What is the procedure for removing/replacing the windshield frame?
Thank you,
Carl
cederholm is offline   Reply With Quote
Old 03-12-2020, 11:16 AM   #2
Terry, NJ
Terry, NJ's Avatar
Default Re: windshield replacement - how to??
Disconnect the swing arms. Bring it up to full open. Prop it open. Lay on your back across the seats and look up at it. You'll note several screws that go up into the header. These wood screws hold the other side of the hinge on. Remove them but be careful. the windshield is fairly heavy and has been known to cause excruciating pain if it hits a body part. It's best to have help with this job.
Terry
Old 03-12-2020, 11:26 AM   #3
cederholm
cederholm's Avatar
Thank you Terry - very helpful!
~ Carl
Old 03-13-2020, 07:42 PM   #4
Big hammer
I used an milk crate on the gas tank, help would have good.
get a bigger hammer tap done
