Old 12-03-2016, 02:24 PM   #21
CarlG
CarlG's Avatar
Default Re: Tube Headers for Model A
Originally Posted by DougVieyra View Post
I really enjoy my Cast Iron exhaust header (manifold) on my Ron Kelley 'Touring' engine. It looks much more stock than the steel headers. Except for some possible 'Dry Lakes' usage, I would like to hear why some prefer 'Tube' headers over the heavier cast iron.
This is Tod's cast iron header on my Ron Kelley Touring engine. Very happy with it.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-03-2016, 09:58 PM   #22
old28
old28's Avatar
CarlG --Where did you get the intake & exhaust manifolds?
What is the compression ratio on the Tod head?
Nice looking motor
old28 is offline   Reply With Quote
Old 12-04-2016, 01:04 AM   #23
DougVieyra
DougVieyra's Avatar
Old28 - "Where did you get the intake & exhaust manifolds?"
You will find them listed on page 141 (intake) and page 142 (exhaust) of SNYDER'S 2016 catalog. Bratton's has them on page 65 of their 2016 catalog. Bert's has them on page 46 (exhaust Header) and page 48 (intake manifold - Weber). I am sure others carry them as well
DougVieyra is offline   Reply With Quote
Old 12-04-2016, 07:11 PM   #24
CarlG
CarlG's Avatar
Nice looking motor
Intake - Snyder's
Exhaust - Tod Buttermore's prototype, now available @ Snyder's
Head - Snyder's 5.5:1
Thanks.
Alaskan A's
Old 12-04-2016, 09:02 PM   #25
old28
old28's Avatar
Thanks for the information on the intake & exhaust.
Old 12-05-2016, 01:03 AM   #26
1929
These are the Reds Tube Headers I bought.
1929 is offline   Reply With Quote
Old 12-06-2016, 02:00 PM   #27
old28
old28's Avatar
Is there any performance difference between a cast iron header and a tube header?
Old 12-06-2016, 04:32 PM   #28
Binger
Binger's Avatar
I met the guys from Geardrive at the Colorado Hill Climb. I am not sure if they build one that is not lake style. Give them a call.
http://www.lakeheaders.com/
Binger is offline   Reply With Quote
Old 12-06-2016, 08:43 PM   #29
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I wanted Reds' to build me a 4 into 4 header for Minerva & they just BLEW me OFF------+*#%^$@+^&
Bill Ticked!
"THE ASSISTANT GURU OF STUFF"
Old 12-06-2016, 11:29 PM   #30
updraught
updraught's Avatar
"4-1 Headers
4-1 headers are designed so that all 4 exhaust pipes merge into one. In most dyno tests, this produces the most top end power since it usually offers the best flow characteristics for the engine at high engine speeds. 4-1 headers usually move the power band up"
https://www.redline360.com/garage/4-...kes-more-power
Somewhere I read the stock exhaust manifold flows quite well up to a point.
http://www.modelaparts.net/dynosheet...ynosheets.html
updraught is offline   Reply With Quote
Old 12-07-2016, 02:02 PM   #31
Zoom
A question for 1929,
How do you like that intake manifold?
I see that Red's sells those as well as tube headers.
Dirk
Zoom is offline   Reply With Quote
Old 12-07-2016, 03:34 PM   #32
colin1928
colin1928's Avatar
Well designed tube headers should be equal length and of a diameter that makes for a scavenge effect that will give a decent power increase
length and diameter are normally the result of trial on a dyno
most of the off the shelf ones I have seen are not equal length so not much better then stock manifolds
colin1928 is offline   Reply With Quote
Old 12-07-2016, 06:36 PM   #33
old28
old28's Avatar
CarlG -- Are you happy with the cast iron Tod exhaust header with your intake and head combination? Do you think a 6.2 head would add any more power or just put a bigger load on the bottom end?
Old 12-07-2016, 06:44 PM   #34
CarlG
CarlG's Avatar
Very happy with Tod's manifold.
I used the 5.5 head on this build just because it is what I had, plus the fact that Ron (the engine builder) said that the difference between the 5.5 & 6.1 wasn't all that great. He said that he could go up to 7. something without causing any problems on the bottom end (It's an inserted engine).
I probably would have opted for one of Tod's new Winfield or Thomas heads, had they been available when I was having the engine built, but it wasn't worth the extra just to buy a new 6.1 from Snyder's at the time over the 5.5 I already had.
Alaskan A's
Old 12-07-2016, 10:15 PM   #35
old28
old28's Avatar
Carl, thanks for the information
Old 12-07-2016, 11:04 PM   #36
1929
Dirk
I like it Dirk, I thought it looked much better then others I saw, just took time to figure out the linkage to the Carb.
Old 12-08-2016, 08:15 AM   #37
BILL WILLIAMSON
We used to reverse the stock throttle arm, to point UP & it worked well, BUT it was a QUICK throttle response, good for layin' SCRATCH-LOL.
With a multi-disc clutch, I could lay a "little" scratch, with a second gear take off! Of course, I had a 4:11 Crown Wheel & Pinion.
Henry would probably have approved some HOT RODDING. One of the Patent Numbers on the firewall plate is for an OHV ROCKER ARM set up! In 1939, Henry commissioned Arkus Duntov, in England, to design & produce the ARDUN OHV set up, for MORE power, for LARGE Ford Trucks! They're a HEMI set up & became VERY popular, in DRAG RACING! The name "ARDUN" was part of his first & last name. An ORIGINAL ARDUN set up will sell for MEGA BUCKS!!!
Later, Duntov worked for Chevrolets' High Performance Division. Remember his "DUNTOV" cams???
Bill W.
