06-25-2011, 02:04 PM | #1 |
Ammeter Test
How can I test an ammeter? In the car is not an option as the car has no wiring in it or lights etc.
Cacey
I can't wait to do more of this. https://www.youtube.com/watch?v=a2IjBUESAEQ |
06-25-2011, 03:05 PM | #2 |
Re: Ammeter Test
Take a flash light battery and connect it across the terminals it should move.
06-26-2011, 02:12 AM | #3 |
Re: Ammeter Test
Hook it in series to a globe.
06-26-2011, 02:35 PM | #4 |
Re: Ammeter Test
Globe?
06-26-2011, 06:16 PM | #5 |
Re: Ammeter Test
Ammeter don't matter about voltage or polarity to see if it works. 6 or 12 battery pos or neg. 1 wire from batt to one side of ammeter. 1 wire from other side of ammeter to one terminal of headlight globe. 1 wire from other side of globe back to batt. Example...12 V battery 55 watt globe should make the ammeter go to 4.5 amps. If you just guess any wire, you have a 50/50 chance it will show 4.5 charge or discharge. It don't matter, it is just a test, and if it works one way it will work the other. Just swap wires. |
