08-22-2020, 10:15 PM | #1 |
Direction of flow
Can anyone confirm direction of flow of coolant thru the heater core? I'm replacing a leaking valve and the new one is directional. Am I correct in thinking coolant flows from top of head thru the valve to the core and returns in lower rad hose to bottom of block. Bypassing the radiator completely. Excuse my rudimentary sketch.
08-22-2020, 10:20 PM | #2 |
Re: Direction of flow
08-22-2020, 10:28 PM | #3 |
correct and flows top to bottom thru the heater core same as rad
08-22-2020, 10:35 PM | #4 | |
Nope, other way around, bottom to top, opposite the radiator. Last edited by JSeery; 08-22-2020 at 11:22 PM. |
08-22-2020, 11:11 PM | #5 |
The coolant flows out of the cylinder heads into the top of the radiator and exits via the lower radiator hose and into the water pump. You must be sleepy,Jerry!
Yes,Will...you are correct with your routing of the core and valve.
08-22-2020, 11:18 PM | #6 | |
The heater install drawings show heater hose from head to the bottom inlet to the heater core and the hose from the top of the heater core to the lower radiator hose. I edited the original post. Last edited by JSeery; 08-22-2020 at 11:28 PM. |
08-23-2020, 08:42 AM | #7 |
Thank you all.
08-23-2020, 10:17 AM | #8 |
Will, here are a couple of photos of the heater installation.
08-23-2020, 10:51 AM | #9 |
My heater is mounted under the seat on drivers(left)side, horizontal/flat on the floor. There is a 2nd 6v fan mounted on the firewall passenger(right) side that is on an aux switch and can be turned on when the heater core is turned on. The output is short with a Y and blows up behind the dash exiting at base of windshield like a modern day windshield defrost.
Pressumably not a stock setup? Or maybe only a Canadian thing. 1938 deluxe Fordor Canadian serial numbers. |
08-23-2020, 11:16 AM | #10 |
The connections should be basically the same, the in and out of the heater core shouldn't make much difference.
