05-08-2020, 11:30 AM | #1 |
'32 Ignition Lock Cylinder Removal
I am restoring a '32 Column Drop and having trouble trying to remove the Ignition Lock Cylinder from the Column Drop. The pin has been drilled out and has been soaking in PB Blaster for a couple of days. The key is in, but unable to turn cylinder and pull out.
Any help on how to get Cylinder out ??? Thanks for all your help. |
05-08-2020, 12:11 PM | #2 |
Re: '32 Ignition Lock Cylinder Removal
You may have drilled too far (or not far enough) and left a burr hanging up in the retaining pin hole. You will likely have to apply some force to the back of the lock cylinder with a hardwood dowel to push the lock cylinder out. Don't use a steel punch as you can ruin the lock cylinder by doing so. It is one of those lessons learned the hard way.
05-08-2020, 01:47 PM | #3 | |
05-08-2020, 02:06 PM | #4 |
If by steering lock barrel you mean the slotted cylindrical piece attached to the steering shaft with two set screws then yes, it can be removed separately, but only if the on/off lever is in the off position. Otherwise the vertical lock shaft is in the down position and engaged in the rectangular opening in the "lock barrel". If that's the case then you either have to free up the keyed lock cylinder so you can turn it to lift the vertical lock shaft or remove the keyed lock cylinder to achieve that result.
05-08-2020, 03:03 PM | #5 |
[QUOTE=DavidG;1885089]If by steering lock barrel you mean the slotted cylindrical piece attached to the steering shaft with two set screws then yes, it can be removed separately, but only if the on/off lever is in the off position. Otherwise the vertical lock shaft is in the down position and engaged in the rectangular opening in the "lock barrel". If that's the case then you either have to free up the keyed lock cylinder so you can turn it to lift the vertical lock shaft or remove the keyed lock cylinder to achieve that result.[/QUOTE
David, No I'm referring to the Steering Lock Barrel that is inside the Column Drop that the Drive Pin and the Ignition Switch Lever are attached to. I am under the impression that this can NOT be removed with the Lock Cylinder in place. How do you get a drift to the back of the Lock Cylinder? Thank you for all your help. |
05-08-2020, 03:21 PM | #6 |
Be careful not to lose the little flat spring that fits in a vertical recess in the bore of the off/on lever. Should you lose it or if it is broken (not uncommon), Michael Driskell (Third Gen Automotive)has a replacement for that spring. |
05-08-2020, 03:23 PM | #7 |
I have freed up the stubborn ones out with a small drift at an angle thru the hole where the pin goes after drilling the pin out carefully.
05-08-2020, 04:16 PM | #8 |
I have found that the lock cylinder will usually go into the drop a small amount further.
I have taken a socket that fits the outer part of the cylinder flat face, put a fiber washer under the socket and tap the cylinder maybe .010. inward. Then I hold the drop in my hand and smack the drop against a soft piece of wood. After a few raps the cylinder will go back to or farther than the original position. Sometimes I have been able to use a small drift in the brass pin hole that has been drilled out to gently pry the cylinder forth and back to start the loosening process. With patience and penetrate, numerous taps back in and smacks against the soft wood the cylinder will come out. I also use this method to remove a broken key that is in the off position. Patience and persistence are sometimes the best tools. Last edited by 34fordy; 05-08-2020 at 04:55 PM. Reason: addition |
05-08-2020, 06:35 PM | #9 |
Will try the Patience and Persistence Method !!!
05-11-2020, 09:37 AM | #10 |
I would be very careful in removing the shaft with the lock cylinder in place. The cylinder protrudes into the relief cut into the shaft and moves it up and down.
I have several shafts that have been damaged beyond repair from driving it out with the cylinder still in place. I always remove the cylinder first. As 34fordy described by soaking it and then tapping hopefully it will begin to move. I use piece of oak cut to the profile of the face on the cylinder. Working it back and forth over time usually works. Try turning the cylinder with a key may help turn it in place. All these parts are almost 80 years old and very delicate. I never use a metal drift as they will usually damage or leave a mark on anything they are placed against. Over the years I have received quite a few damaged column drops and cylinders that are unrepairable usually because of improper over zealous removal methods.
Early Ford Lock & Key Service http://www.fordbarn.com/forum/showthread.php?t=46583 |
05-11-2020, 10:34 AM | #11 |
Phil is correct; please ignore my #6 posting.
05-11-2020, 07:23 PM | #12 | |
