10-14-2019, 06:57 PM | #1 |
Front Axle Movement
The grandkids were pretending to drive the Model A the other day and I happened to be in the front and noticed when the steering wheel was turned the front axle moved back and forth on the drivers side. I had replaced the wishbone rubber ball and related parts, but have a feeling there shouldn't be that kind of movement in the front axle from the force of the drag link or is some movement of the axle to be expected?
10-14-2019, 07:54 PM | #2 |
Re: Front Axle Movement
Might check the junction of the radius rod and axle and ensure the thru bolt is tight. Don't think there should be any movement.
10-15-2019, 03:43 AM | #3 |
Unfortunately that is the product of using those rubber wishbone ball kits. Not only do they affect steering, they also affect front brakes. Your options are to leave it as-is, -or restore the radius rod ball to 1.500" diameter again and install a new ball seat.
10-15-2019, 02:12 PM | #4 |
Thread Tools | |
Display Modes | |
