Old 11-22-2010, 01:25 PM   #1
brum1
brum1's Avatar
Default Upholstery question - 30 Coupe Rumble Area
Hello All,
The upholstery panel on the rear of front seat (as viewed from the rumble seat)does not cover the entire area. A 4" gap was left on the bottom. Is this correct?
Also, for the rumble panels on either side of the rumble seat, what type of fastener is required to attach to the slat?
Thanks in advance,
"No one is smarter than everyone"
brum1 is offline   Reply With Quote
Old 11-22-2010, 05:33 PM   #2
Aerocraft
Aerocraft's Avatar
Default Re: Upholstery question - 30 Coupe Rumble Area
The area at the bottom of the back of the rear seat below the upholstery panel is covered with carpet when the car is a Deluxe Coupe. I don't know what is used for the Standard Coupe when it has a rumble seat. The side panels are secured with a slotted wood screw and a finishing washer. Gar Williams
Aerocraft is offline   Reply With Quote
Old 11-22-2010, 07:35 PM   #3
brum1
brum1's Avatar
Thumbs up Re: Upholstery question - 30 Coupe Rumble Area
Gar-Thanks for the confirmation,
Old 10-05-2019, 01:09 PM   #4
dmaxweb
dmaxweb's Avatar
How is the carpet attached?
Do you have a picture?
Thanks
dmaxweb is offline   Reply With Quote
