02-02-2016, 09:02 PM | #1 |
Lug Nuts 35 Ford Wheels
I suspect my frustration with fitting the lug nuts into the '35 Ford wire wheels might be shared by many and has been around for a while (since 1935).
The deep recess of the wheel prevents a standard socket and extension from getting straight on to the nut and 50+ year old fingers don't reach well into the wheel to get the nuts started. A short thin wall 3/8" drive socket and extension might create some extra clearance/alignment. Strategically placed notches ground into the inside diameter of the hubcap opening might also help. Are there any tips from "back in the day" Thanks in advance Fordbarn. |
02-02-2016, 09:31 PM | #2 |
Re: Lug Nuts 35 Ford Wheels
Being a new guy here, I don't have old school advice, but I also have 36 16 inch wheels and found a regular socket with 1/2 inch extension works and doesn't seem to be crocked. I suppose you could gain a little clearance using a 1/2 socket and an adapter to convert to 3/8 inch so you could use a 3/8 extension. Then the decision would be to use a 3/8 wrench or convert back to 1/2 inch. But in my case, I'm able to go 1/2 all the way without any problem.
02-02-2016, 11:49 PM | #3 |
I just use a 1/2" drive socket and a 1/2" extension.
I do not seem to have a problem and have been doing it for more than 50 years. My experience, Chris W. |
02-03-2016, 11:03 AM | #4 |
I use a 1/2" drive socket and a 3/8" extension
I've been doing so much for so long with so little that now I can do almost anything with nothing. |
02-03-2016, 11:12 AM | #5 |
They're NO problem, using an "X" type lug wrench. I use the later lug nuts, that helps also.
Bill W.
02-03-2016, 11:35 AM | #6 | |
https://www.youtube.com/watch?v=3Bcpjf6_vCk |
02-03-2016, 11:44 AM | #7 |
Phred, if you're having trouble w/a regular 1/2" drive socket and extension you might try a wobble extension, it'll give you about 15º of flex.
