02-01-2016, 03:09 PM | #1 |
Marvel Carb Leak
I have a Marvel carb and it is leaking out of the GAV entry. I have rebuilt the shut off and it does not leak. But the carb leaks some. Is the GAV supposed to seal when totally closed or do I have the float set wrong. Any advice is appreciated.
02-01-2016, 03:19 PM | #2 |
Re: Marvel Carb Leak
Could be the float is too high, or the casting might have a crack at the GAV threads.
02-01-2016, 03:34 PM | #3 |
The GAV boss should be a pipe thread so as to seal off. I use a small amount of pipe dope on the threads. Quite often someone in the past may have run a regular tap through it which will destroy the sealing capability.
Tom Endy |
02-01-2016, 04:17 PM | #4 |
It appears that the leak is not at the threads but where the shaft exits the brass fitting.
02-01-2016, 04:19 PM | #5 |
Is there a procedure for checking the float position and adjusting if necessary?
02-01-2016, 06:25 PM | #6 |
