02-01-2016, 11:21 AM | #1 |
Steering arm torque?
No torque listed in my book for these.
Anyone have a number for me, for when these come in and I reinstall.
02-01-2016, 01:03 PM | #2 |
Re: Steering arm torque?
Tight.........
Paul in CT I don't believe there were ever any torque values published for an A, only later did values come about for head, rear axle, etc. Common sense comes into play here also. |
02-01-2016, 04:32 PM | #3 |
the torque is, a big socket, a long breaker bar and strong arms, if your real nervous use lock tight on the threads
02-01-2016, 05:34 PM | #4 |
A long breaker bar may break a bolt.
02-01-2016, 06:10 PM | #5 |
Tight!! I have used two combination wrenches,box end on nut,2nd wrench box end thru
the first open end,making cheater wrenches. Tighten,smack bolt head,then tighten 1/8 of a turn more. If that bolt/nut comes loose, you and your car will look ugly :-( |
02-01-2016, 06:32 PM | #6 |
02-01-2016, 09:31 PM | #7 | |
Good enough.. Isn't. |
02-01-2016, 09:46 PM | #8 |
Tighten tight cotter pins bent correct when in doubt lock tite blue . I plan on a banzi 150 mph run in my 27 essex every thing is tight and cotter pined plus blue lock tite.I aint scared
