10-04-2019, 04:49 PM | #21 |
Re: Bouncey Car Needs Shocks
$1240/4 as per Stipe's web site.
10-04-2019, 05:29 PM | #22 |
Okay Thank You.I have gone to the web site several times and click on shocks nothing happens on anything.
"Never complain,never explain"... Henry Ford II Last edited by 37 Coupe; 10-06-2019 at 05:09 PM. |
10-04-2019, 06:40 PM | #23 |
10-05-2019, 08:11 AM | #24 |
Thanks all for your advice. I am going to adjust the rear Houdaille shocks to stiffen the ride, and adjust the front Houdaille shocks to soften the ride.
Should the Houdaille shocks fail to make the car comfy for my backseat driver, then I will convert to modern telescoping shocks. My 190A needs to be roadworthy for the trip to the 2020 New England Meet in Newry, Maine.
Bob Bidonde Last edited by Bob Bidonde; 10-05-2019 at 08:18 AM. |
10-05-2019, 09:33 AM | #25 |
I wouldn't convert until trying different weight oils versus the glycerin originally used. A good anti foaming oil should work well in that application. Often folks are too quick to throw parts at a problem before seeing if the original stuff is actually working correctly.
10-05-2019, 10:19 AM | #26 |
10-05-2019, 12:18 PM | #27 |
Hi Purdy,
Yes you can, but the Houdaille shocks must come off of the car to change the fluid. To get the fluid out, cycle the shock upside down with the drain plug out.
Bob Bidonde |
10-05-2019, 12:34 PM | #28 |
Thanks Bob !!! Cycle the Shock upside down with the drain plug out is good info !!!!!!!
10-05-2019, 04:59 PM | #29 |
Ken Davis won't fit on a Vickey rear. No Room for top bracket
10-06-2019, 03:25 PM | #30 |
Oldbird55, I have a Victoria and before I bought my modern shocks, I called and talked to Ken Davis and I was told that his shocks will fit the Victoria! I've installed the front ones, love ❤️ them! Haven't put the rear on yet. Where did you get your information?
10-06-2019, 03:33 PM | #31 | |
10-06-2019, 05:00 PM | #32 |
Let us know how you make out
