Old 08-16-2017, 10:53 AM   #1
Jeff M
Default When installing the rear axle...
Is it necessary to have the rear wish bones attached first? I'm about to install the rear but it won't have the brakes on at the moment because I need to lap the axle tapers.
Jeff M is offline   Reply With Quote
Old 08-16-2017, 11:06 AM   #2
larrys40
Default Re: When installing the rear axle...
No it's not necessarily but easier if you wish to deal with the forward attaching bolt. You. An install the radius rods with the long forward backing plate bolts and put the brakes in later
Larry shepard
larrys40 is offline   Reply With Quote
Old 08-16-2017, 12:16 PM   #3
hardtimes
hardtimes's Avatar
No !
I've found that it is easier not to.
hardtimes is offline   Reply With Quote
Old 08-16-2017, 12:22 PM   #4
Jeff M
Great, thanks for the replies, still learning as I go!
Old 08-16-2017, 05:28 PM   #5
Synchro909
Synchro909's Avatar
It seems to me that if there are 2 ways to do a job, someone on this forum will come up with a third!
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 08-16-2017, 06:53 PM   #6
redmodelt
redmodelt's Avatar
I would rather install with the backing plates, brake, drums and radius rods in place. It is a hell of lot easier to install the parking brake springs with the axle out from under the car. Does that count as a 3rd way?
Old 08-16-2017, 08:35 PM   #7
Big hammer
No on the third way, it's the onlyway :-)
get a bigger hammer tap done
