06-15-2016, 02:51 AM | #1 |
'32 frame same as Model A?
Did the '32 Model B pickup use the same frame as the Model A?
If not, what are the differences? Can an A frame be used to build a '32. Thanks. |
06-15-2016, 03:09 AM | #2 |
Re: '32 frame same as Model A?
http://www.wescottsauto.com/WebCatal...ram1928-31.pdf
http://www.wescottsauto.com/WebCatal...m1929Hiboy.pdf http://www.wescottsauto.com/WebCatal...iagram1932.pdf Let the numbers do the talking, no it's not going to work, plus the 32 frame is to nice not to use. Strength is also a consideration. Last edited by my4dv8; 06-15-2016 at 03:48 AM. |
06-15-2016, 03:17 AM | #3 |
No. Very different.
06-15-2016, 03:58 AM | #4 |
The only two things in common between the two are their names (frame) and their material (steel) and perhaps a few rivet sizes.
06-15-2016, 06:44 AM | #5 |
Yes very different but you can mount a 32 truck cab on a model a chassie . You'll have to use the model a fenders and box. I have a friend that did this many year's ago and looked great and gave him a bit more room in the cab.
I am sure the purist don't want to hear this so the jalopy journal or hamb would be a better place to discuss this. You can shoot me a message as well , I'll look to see if I can find a picture of Scott s truck.
Wanted Roadster Pick up thank you COLOR] |
06-15-2016, 09:22 AM | #6 |
06-15-2016, 09:30 AM | #7 |
06-15-2016, 09:38 AM | #8 |
Huh? Mounting the '32 or '33/34 cab on the A frame is not going to provide any more room in the cab than it would on the correct /32 or '33/34 frame.
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
06-15-2016, 10:15 AM | #9 |
Thanks, great info. Gives me a path to keep going.
06-15-2016, 10:17 AM | #10 |
08-26-2016, 04:00 PM | #11 |
Yes that is how I took it, not much more room either maybe 6 to 8 inches .
