Old 05-08-2019, 11:55 AM   #21
Badpuppy
Default Re: Why can't my generator move?
Originally Posted by Sparky View Post
I think my pipe most resembles the A-8291-B which is second from the top.
To my eye it looks more like the top one. But then, you're a lot closer to it than i am.
I believe the dates shown correspond to the three generators used on the model A - Powerhouse (top), "long nose" (second) and "short nose" (third).
Your generator is a short nose. If your car is a 1928 model, it probably had the Powerhouse generator originally.
Old 05-08-2019, 05:44 PM   #22
ericr
ericr's Avatar
the '29s connection seems tight at best, but I had the better luck using the earlier Powerhouse tube rather than the one-size-fits-all since it has more clearance designed into it.
ericr is offline   Reply With Quote
Old 05-08-2019, 09:42 PM   #23
Tom Wesenberg
Tom Wesenberg's Avatar
Wonder who started the rumor about a "Powerhouse pipe"?
There is no such thing. The lower pipe is made for 1928-1929, or 1930-1931.
The 28-9 radiator should have the bottom outlet pointing slightly outward and the pipe should match it. The pipe should have the bend down low, and not near the center, as the 30-1 pipe does. Your pipe and angle look wrong to me.
Old 05-09-2019, 08:40 AM   #24
Sparky
Sparky's Avatar
I don't know if anyone started a "rumor", but that seems to be the way the suppliers describe them. For example here is the description from Snyders:
Sparky is offline   Reply With Quote
Old 05-09-2019, 10:24 AM   #25
jimvette59
jimvette59's Avatar
Turn your pipe around.
jimvette59 is offline   Reply With Quote
Old 05-09-2019, 11:23 AM   #26
Sparky
Sparky's Avatar
That would help with the clearance but then the drain would be in the wrong spot.
Old 05-09-2019, 03:00 PM   #27
ericr
ericr's Avatar
well to add to the rumor mill, doesn't the lower radiator hose on the '29 get twisted a tiny amount when connected to the pipe, whereas on the 30-31 the connection is a complete straight shot into the lower tank?
Old 05-09-2019, 03:14 PM   #28
Bob C
Not with the right pipe.
Bob
Old 05-09-2019, 05:11 PM   #29
Sparky
Sparky's Avatar
Thanks for the picture Bob, I think that pipe will solve my problem. Very nice looking engine, is it yours?
Old 05-09-2019, 06:37 PM   #30
Bob C
I wish. That is Gary Karr's 492 point Tudor.
Bob
Old 05-10-2019, 06:20 AM   #31
ericr
ericr's Avatar
Bob
not to prolong this unduly, but isn't that Powerhouse resting right against the hose clamp, or is that my glasses?
