Old 05-24-2021, 11:31 PM   #21
eagle
eagle's Avatar
Default Re: Slight Grinding when shifting - transmission oil Aerated
100 percent lucas oil stabilizer in my A transmission. Smooth as silk. Definitely made shifting easy, had some of the vendor 600w in it, foams up, terrible fade.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is online now   Reply With Quote
Old 05-26-2021, 01:35 PM   #22
wwirz
Seems like the main source of the grinding was that the idle was set too high on the column. The tranny is happier now...even on a hot day. Thank you. Sometimes the little things add up......
wwirz is offline   Reply With Quote
Old 05-27-2021, 10:18 AM   #23
Bob Bidonde
Bob Bidonde's Avatar
I have had the aeration problem in a newly rebuilt transmission using the so called 600W oil. Anything with a 600W label on it cannot be trusted. SAE 75W140 Gear oil is the way to go for the Model A's transmission and differential.
Bob Bidonde
Thread Tools
Display Modes
