Old 06-29-2012, 06:17 PM   #1
lupie989
Default motor still stalls
The ignorant one here again. The engine will start up, run strong for 15-20 seconds and then just die. I have..replaced the carb, removed the add-on inline filter, removed the gas cap ,installed a new coil. The timing and dwell are O.K. Chocking the engine will not keep it running. How about the condenser?
lupie989 is offline   Reply With Quote
Old 06-29-2012, 06:49 PM   #2
700rpm
700rpm's Avatar
Default Re: motor still stalls
It's a fuel problem, not an electrical problem. Disconnect your gas line at the carb and see if you can drain about a gallon or two of gas out of your tank. If it stops shortly after you open the valve and refuses to drain, you know it's something between the tank and the carb. Probably rust and junk in the gas tank clogging the flow out of the tank. And if you decide that's it, get one of those screen filters that goes on the top of your shut-off valve, install it, and see if that takes care of your problem.
Ray Horton, Portland, OR
Old 06-29-2012, 06:51 PM   #3
mach0415
mach0415's Avatar
Sounds like the carb float is set too low - even if its a new carb, you should check it. Take low pressure air hose and blow back through the fuel line with the cap off to see if there is a blockage. Does it start immediately after it dies? or Does it take a while of cranking before she comes back to life?
Thanks,
Mark in SC
"We the unwilling, led by the unknowing, are doing the impossible for the ungrateful." -- By society, who is still arguing over who said it.
mach0415 is offline   Reply With Quote
Old 06-29-2012, 07:00 PM   #4
Bob C
You fully retard the spark when you start the engine, does it die with the spark still
fully retarded or after you advance it a little? I'm wondering if the wire on the lower
distributor plate is grounding when you advance the spark.
Bob
Old 06-29-2012, 07:07 PM   #5
J Franklin
J Franklin's Avatar
Have you performed the tests listed in the other thread you started yet?
Old 06-29-2012, 07:19 PM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Lupie,
Don't get 2 threads started at once, too confusing. Just add to your original & it brings it to the top again. BillW.
"THE ASSISTANT GURU OF STUFF"
Old 06-30-2012, 12:18 AM   #7
700rpm
700rpm's Avatar
Bill gave you the same suggestion in your thread yesterday that I gave you today. J Franklin is right: Did you do that yet?
And Bill's suggestion today is also a good one.
Old 06-30-2012, 08:17 AM   #8
Patrick L.
Patrick L.'s Avatar
Apparently he didn't check what we have suggested.. Until he does that,, he really can't be helped.. His problem seems like fuel flow [if the carburetor is set correctly],, but,, he hasn't answered us..
Old 06-30-2012, 05:26 PM   #9
lupie989
Thanks for all your help guys. It turned out to be a plugged line between the sediment bowl and the gas tank. I really appreciate all the advice.
Old 06-30-2012, 06:03 PM   #10
700rpm
700rpm's Avatar
Glad you found it. Thanks for letting us know.
Thread Tools
Display Modes
