10-10-2017, 07:26 PM | #1 |
Pulled the Steering Box Today
My '29 Special Coupe 7-tooth steering box needed a rebuild badly, so today I tackled the task of removing the box and column from the car. This was my first try ever and I felt apprehensive about tackling the job alone. I followed Les Andrews' book - plus some shortcuts and took the assembly (with steering wheel attached) out from the driver's side. I was surprised how EASY it was..in under 2 hours!
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
10-10-2017, 09:07 PM | #2 |
Re: Pulled the Steering Box Today
Now the fun begins! But it is well worth the effort to rebuild it and get some good steering.
Fred Kroon 1929 Std Coupe 1929 Huckster |
10-10-2017, 10:19 PM | #3 |
Resist the temptation to use a "knocker" to remove the steering wheel. Those darned things have ruined more steering shafts than Father Time or Mother Nature ever have. Buy, beg or borrow a dedicated Model A steering wheel puller. You wouldn't believe how stuck some of these wheels are, even with a puller. I've bowed my two-piece puller on several steering wheels until they finally popped (and I mean POPPED!) loose.
Be sure to put a good sized bolt down the top of the steering shaft before tightening the puller. Otherwise, you run the risk of mushrooming or even breaking the top of the shaft. Marshall |
10-10-2017, 11:12 PM | #4 |
John in same weather Suffolk County England . PS You would need to get a keyed 29 steering wheel as well. |
