Old 12-14-2015, 12:57 PM   #21
fredski
fredski's Avatar
Default Re: Dwell Angle
Originally Posted by Mitch//pa View Post
I used the B cams in both my cars purchased from brattons / swapped out the A cams... Very high quality and a noticeable improvement as well
Are you speaking about camshaft or cam in the distributor?
If distributor do have to modify b cam to fit.
Not understanding this quite.
Fred
fredski is offline   Reply With Quote
Old 12-14-2015, 01:02 PM   #22
fredski
fredski's Avatar
Okay to all , will give up dwell adjustment on the A .
It does work well on my 1963 (xxx) .
Fredski
Old 12-14-2015, 01:04 PM   #23
Mitch//pa
Fred
The cam in the distributor:::: no modification needed:::::but do a timing and point gap reset after installation
Old 12-15-2015, 06:38 AM   #24
RonC
RonC's Avatar
A dial indicator setup on the back of the points is rhe most accurate way to set them. You can also check the variation in the cam lobes.
RonC is offline   Reply With Quote
