02-24-2024, 03:58 PM | #1 |
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
Rotor position at TDC
I swapped out the distributor on my '31 Tudor 12v engine.
Next I was gonna set the timing using the Nu-Rex tool. I am visibly at TDC on #1 piston and get a slight motion on the timing pin against the timing gear but it does not readily go into the timing gear hole. I assume the timing pin is just too tight a fit. Anyway, I was expecting to see the rotor at the #1 cylinder pin in the distributor cap. Instead the rotor is 180 off from where I expected it to be. Is this rotor position normal or am I missing something? |
