02-10-2022, 12:37 PM | #1 |
Holley 94 on early 35 aluminum manifold
I'm having trouble with my 59 series 94 carb on an early 1935 aluminum manifold. I have rebuilt it, cleaned all the holes, many times. Ordered the correct 7.5 pv that has been machined flat, and 51 jets. All of this is on a rebuilt stock 59ab, .060 over. Someone on the Hamb said the gaskets for a stromberg 97 and a 94 are different because of the power valve. That's why I'm wondering if the base on the manifolds are different. I will be trying to find my 59ab manifold to check. Thanks Ron
02-10-2022, 01:21 PM | #2 |
Re: Holley 94 on early 35 aluminum manifold
Should work fine I would think.The 94's have a chevron base instead of a "D" base .Contact Charlie ny, on here for expert advice
02-10-2022, 01:54 PM | #3 |
The Holley 94 has a slot machined in the base to allow vacuum to the power valve.
Will work on either manifold. Sal |
02-10-2022, 02:02 PM | #4 |
Thank you both for your reply, so I just need the correct gasket for a 94. Thanks Ron
02-10-2022, 02:44 PM | #5 |
ron,
Be sure your intake does not have a hole between the 2 front attaching studs....this intake suitable for Strombergs only. That hole goes into the exhaust crossover passage and supplies heat to the carb...ok for Stromberg but the heat will ignite the power valve on a 94. Either gasket OK. Charlie ny |
02-10-2022, 03:37 PM | #6 |
