Old 05-27-2021, 07:43 AM   #21
50FlatheadVert
50FlatheadVert's Avatar
Default Re: Optima 6V Battery Mounting Options
I ended up ordering a case through eBay and hold down hardware through Shoebox Central
2009 BMW 135i, 2017 GTI S, 1990 SSP Notch (SOLD), Other Foxbodies (SOLD)
50FlatheadVert is offline   Reply With Quote
Old 05-28-2021, 06:16 PM   #22
FlatheadTed
FlatheadTed's Avatar
More Battery options ,the steel bracket is a modified , using the lugs that came with it ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 05-29-2021, 12:07 AM   #23
Tinker
Tinker's Avatar
Ammo cans? I'm guessing a block of wood would be better and less ratty. Optima's can also be laid on it's side. Well really upside down. No fluid to contend with.
Old 06-18-2021, 11:20 AM   #24
50FlatheadVert
Latest in the battery adventures...I got a case off of ebay per a forum member's suggestion (perfect!), then ordered the factory hold down kit from Shoebox Central and stupidly I did not account for the taller optima battery so I picked up some generic hold down rods which I need to cut then I'll post the results
Hard to believe it's taking this much time just to get the battery right
