08-16-2016, 09:18 AM | #1 |
'40 half-ton and one ton rear fenders
I've been looking for '38-'41 rear fenders for my '38 half ton pu. I came across some '40 one ton rear fenders listed for sale but I assume these are different from half ton. Am I correct? I couldn't find one ton pu fenders in the Green Bible to compare. He also has a '40 woody rear fender. Would it be worth getting for trading stock? Jim
08-16-2016, 10:09 AM | #2 |
Re: '40 half-ton and one ton rear fenders
1/2 to and 3/4-1 ton rear fenders are very different.
1/2 ton fenders are reproduced in fiberglass, 3/4-1 ton are not. Both the 3/4-1 ton and woody fenders fall into the category of parts that are hard to find, and hard to find someone who needs them, so judge accordingly. |
08-16-2016, 10:14 AM | #3 |
38 to 41 half ton fenders are hard to findo. I have been using 42 to 47 fenders and changing the bottoms at the running boards to fit.
08-16-2016, 12:05 PM | #4 |
This is exactly what I have recently done. Also had to "insert" the dimple for the spare tire. All easy enough...
08-16-2016, 02:09 PM | #5 |
08-16-2016, 04:50 PM | #6 |
These carried the spare in the driver side but it didn't encroach on the fender. Much easyer to find and less green to purchase than 40-41. Martin. |
08-16-2016, 05:25 PM | #7 |
The wheel opening may be different between the years also.
On my '41, one side is 1" wider than the other. ??????????? |
08-19-2016, 10:28 AM | #8 | |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
