01-07-2022, 12:13 PM | #41 |
Re: I think it's time to move to an alternator
Where's your sense of adventure?
01-07-2022, 08:51 PM | #42 |
With my FP voltage regulator, I have the best of both worlds I believe. Regulated battery charging, original generator. Have they started making them again? Last I heard they were NOT.
01-08-2022, 08:14 AM | #43 | |
01-08-2022, 08:33 AM | #44 | |
01-08-2022, 10:04 AM | #45 |
Stay away from the FP regulator. When (not if) it fails it may take your generator with it. Elegant circuitry, but flawed design. Unlikely it will be revived.
James Peterson claims 15 amp current limit, but I don't see a sensor in the output path. It looks like a good design though. |
01-08-2022, 12:03 PM | #46 |
The Field terminal (FLD) goes to the wire that was removed from the third brush. The BAT terminal goes to the battery. The ARM terminal goes to the generator, either before or after the cut out. The regulators have a cutout built in so the old cutout can be bypassed. There are 2 wires going to the generator but they can be lead inside the conduit to be not visible. Do not use the regulators for GM cars because the field function is different.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 01-08-2022 at 12:11 PM. |
