Old 11-28-2021, 12:41 PM   #1
doug.nichols
doug.nichols's Avatar
Default Throttle Bracket Rubbing
Just finishing an engine swap. Got to looking at the throttle bracket. The arm that holds the pedal rubs against the upright to its left when fully depressed. See pictures attached. At close inspection, it appears that the pedal arm might have been welded and/or bent in the past which might be contributing to the problem. Opinions? Thoughts on remedy?
Thanks,
Doug
doug.nichols is offline   Reply With Quote
Old 11-28-2021, 01:19 PM   #2
old ugly
old ugly's Avatar
Default Re: Throttle Bracket Rubbing
it looks to me that someone has added a new end onto the arm and it is a bit too thick.
if function is more important than correctness then if it were I, just file or grind some clearance into the new section.
if correctness is important then you will have to
1-replace the whole thing
2-cut off that pc and weld on a correct chunk
or
3-reshape the whole thing with a grinder or file.
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
Old 11-28-2021, 01:21 PM   #3
old ugly
old ugly's Avatar
it also looks to me that the top shaft is no longer straight. but maybe its just the pic.
old ugly
Old 11-28-2021, 01:45 PM   #4
doug.nichols
Old Ugly
Thanks, I came to a similar conclusion. I emailed Bert's to see what they have on the shelf, but am ok with grinding/filing if I need to.
Old 11-28-2021, 03:19 PM   #5
Brentwood Bob
This looks like the correct bracket for the early 28.
There were 5 different designs.
The judging standards would clarify this for you, but Berts will know the differences.
I have several of each but the early ones are rare.
What is your build date?
Brentwood Bob is offline   Reply With Quote
Old 11-28-2021, 03:42 PM   #6
doug.nichols
The majority of evidence suggests that the car is a mid to late 1928.
Old 11-28-2021, 10:36 PM   #7
Brentwood Bob
Page 1-17, revised 2016 of judging standards has the series.
Old 11-29-2021, 11:55 PM   #8
al's28/33
al's28/33's Avatar
You'll find that all or most throttle assemblies have been bent at some point with folks removing engines, bodies and farmer fixes. I went thru 4 or 5 assemblies to create my own very neat linkage that clears the firewall and has full use of range with both foot and hand throttle controls. This takes time and patience to adjust, remount, experiment, remove, adjust and remount to get all the working parts moving freely without hang up. A little bend or filing goes a long way, don't get impatient. You will feel so much happier in the long run when the "A" functions normally as it was intended.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 11-30-2021, 12:14 AM   #9
Brentwood Bob
Great advice Al. I have reworked some bent ones to get them trued-up and straight. Takes time and patience.
