11-14-2019, 02:46 AM | #1 |
brake press. switch
I have seen , either here or the early V8 forum, that some guys are replacing bad brake light pressure switches with a pressure switch from Harley-Davidson. I thought I had written the part # down, but can not find it. anyone know what the part # is ? The switch on my avatar has gone bad, and I need a good quality switch to replace the one on the car. Thanks for any help anyone can provide.--- Jim
11-14-2019, 12:05 PM | #2 |
Re: brake press. switch
Here you go Jim - https://www.summitracing.com/search/...fluid-pressure
A complete collection. EDIT - Here is a HARLEY style switch. Don't know the quality.
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 11-15-2019 at 01:09 AM. |
11-14-2019, 03:43 PM | #3 |
This is from my posting on the HAMB:
Originally Posted by 51504bat Someone here or on the HAMB posted a link for a low pressure switch. I've got the info at home in the shop. If no one posts the info I'll post it later today. I bought one and so far so good about it working and working on a lower pressure The low pressure switch was from Classic Performance Products in Placentia, CA 800-522-5004 Part number CPP-LBPS They list it as 45psi. Cost in August was 16 bucks plus tax shipping included.
Making the simple complicated for over 30 years. |
11-14-2019, 05:14 PM | #4 |
I am using the Harley Davidson brake light switch on the car in my avatar, but I don't recall the plastic package having a part #. I got it at the counter of a bike shop here in town.
But other folks here know what it is. That's how I got turned on to it. |
11-14-2019, 08:51 PM | #5 |
Ron Francis has a hyd. , low pressure switch , DOT 5 compatible, so they say. It does have different connector but comes with its own connector.
11-15-2019, 12:59 AM | #6 |
11-15-2019, 01:00 AM | #7 | ||
The only problem I see is the switch using GM style terminals. I know I have seen this rating switch using FORD pins. SOURCE - https://www.ronfrancis.com/prodinfo.asp?number=SW%2D32
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
11-15-2019, 01:51 AM | #8 | |
https://www.inlinetube.com/products/bs04
11-15-2019, 02:17 PM | #9 |
This is the one I'm using, works well, trips at a low PSI.
https://www.ebay.com/itm/Chevy-Ford-...53.m1438.l9372 |
11-15-2019, 02:50 PM | #10 |
Harley part number is 72023-51b and is DOT5, silicone compatible.
