Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 01-12-2015, 01:23 AM   #1
wingerdinger
wingerdinger's Avatar
Default FOUND! `35 cast iron intake with tall generator mount
City: Minneapolis
State: Minnesota
FOUND ONE THANKS GUYS
I need an intake manifold with the taller 4" generator flange.
Here are the dimensions:
Each measurement is taken from the base of the manifold, where it mounts to the engine.
The pump/vent height is 2 5/16"
The carb mount is 5 1/8"
The generator mount is 4" to the top, and about 3 1/2" to the center of the bolt.
I want to stay correct with cast iron.
I will need a vacuum port, mine is below the 3rd bolt from the front, on the drivers side.
wingerdinger is offline   Reply With Quote
Thread Tools
Display Modes
