05-27-2020, 01:44 PM | #1 |
Original shocks on lowered car
I have just replaced the springs on my car with new reversed eye springs from Posies. These springs will give me a two inch drop. I realize this will change the amount of upward travel of the shock arm. Without going to tube shocks what are my options to correct this ?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
05-27-2020, 01:49 PM | #2 |
Re: Original shocks on lowered car
Several options. Shorten a dogbone connector by an inch or so and re-weld it together. You can use just one bolt and weld a key to one of the halves to keep the dogbone correctly indexed.
The other option is to heat & bend, -or section the shock arm on an angle and re-weld it. Probably 15° - 20° of an angle would be enough, and then use stock length tubular links or the later dogbone connectors. |
05-28-2020, 12:47 AM | #3 | |
05-28-2020, 11:01 AM | #4 |
Before you do anything, manually check to see if they have enough travel as-is, you may not need to change anything???
05-28-2020, 08:16 PM | #5 |
Wanted flathead speed equipment Thanks |
