05-22-2020, 08:01 AM | #1 |
Conventional Cap
Is a conventional or modern style distributor cap only available from the Model A parts suppliers?
05-22-2020, 08:08 AM | #2 |
Re: Conventional Cap
both.
05-22-2020, 11:52 AM | #3 |
You can find them on EzPay at times.
05-22-2020, 03:36 PM | #4 |
Does it fit anything else besides a Model A and B distributor?
05-23-2020, 01:03 AM | #5 |
I use the standard distributor cap, but have converted it to use modern plug wires as I have also converted to a 12 volt system. I use the modernized internal components as well with the modern points and condenser that provided greater reliability. Henry was not wrong, but l need more assurance to get to work on any given dayl
05-23-2020, 05:44 AM | #6 | |
How did you convert the standard cap to use modern wires? |
05-23-2020, 01:06 PM | #7 |
https://brillman.com/rajah-terminals/
Something like the first one could be used at both ends if you wanted to stay with original style body.
I know the voices aren't real but damn they have some good ideas! |
05-28-2020, 06:32 AM | #8 |
Thank you.
05-28-2020, 09:07 AM | #9 | |
I believe that NAPA can get both original and conventional distributor caps plus most other mechanical parts for the model A . My experience has been that model A parts are much less expensive when purchased from model A parts vendors . |
