Old 03-30-2021, 08:29 PM   #1
Huff
Send a message via ICQ to Huff Send a message via AIM to Huff
Default Sparte tire carrier on a 48/52 pick up
What size tire are you using for the spare tire. thanks?
Huff is offline   Reply With Quote
Old 03-31-2021, 02:35 AM   #2
FortyNiner
FortyNiner's Avatar
Default Re: Sparte tire carrier on a 48/52 pick up
In my case, same as the other 650-16 bias ply tube type; bone stock here. The under bed carrier can't handle anything much wider than these. The radial tire users need to modify the carrier or figure out a side or end panel based arrangement on the bed itself.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 03-31-2021, 12:40 PM   #3
alanwoodieman
215 75 r 16
alanwoodieman is offline   Reply With Quote
