Old 02-04-2019, 03:02 PM   #1
Huff
Send a message via ICQ to Huff Send a message via AIM to Huff
Default coil hook up
6 volt pos ground does the+ or - go to the points this is on a 52 Ford f1
Huff is offline   Reply With Quote
Old 02-04-2019, 03:14 PM   #2
flathead4rd
flathead4rd's Avatar
Default Re: coil hook up
Negative
flathead4rd is offline   Reply With Quote
Old 02-04-2019, 03:24 PM   #3
tubman
tubman's Avatar
To be clear : When the points close, the connection through the coil is made because the points are grounded. Therefore, in a Ford that has a positive ground system, the "+" marked terminal on the coil should be connected to the distributor.
Old 02-04-2019, 03:30 PM   #4
JSeery
JSeery's Avatar
The (+) goes to the points.
Old 02-04-2019, 03:31 PM   #5
deuce_roadster
deuce_roadster's Avatar
Since the points eventually go to ground, wouldn't on a + ground system, the wire to the distributor from the coil (assuming a can type coil) would be from the + term of the coil ?
On neg ground cars, the wire from the - pole goes to the distributor. Essentially matching the ground of the overall system. Or have I had that wrong for over 50 years?
I see others beat me to it.
Old 02-04-2019, 06:47 PM   #6
zzlegend
zzlegend's Avatar
It will run either way and i bet a lot of people have them hooked both ways. It just won't be as effective if hooked up backwards. I have two of these in my tool boxes. Can't go wrong. Plus i never trust coil markings in today's world.
https://www.snydersantiqueauto.com/polatity-tester
zzlegend is offline   Reply With Quote
Old 02-04-2019, 09:45 PM   #7
Tinker
Tinker's Avatar
... just adding to the same
