Old 02-20-2012, 07:47 PM   #1
PO51
PO51's Avatar
Default fuel pump
anybody here put an electric fuel pump on a Model T? If so which one did you use? Need to install one on another antique car looking for info.
Thanks
PO51 is offline   Reply With Quote
Old 02-20-2012, 07:58 PM   #2
fordman67
Default Re: fuel pump
That is the beauty of a t......we don't need no stinking pump for nothing!
1925 tudor (restoration)
1941 tudor"street rod" project1964 fairlane tube chassis "street car"
1996 f-350 crew cab 4x stroker!
Na, I dont like working on cars...I exist for it!
fordman67 is offline   Reply With Quote
Old 02-20-2012, 08:03 PM   #3
yachtsmanbill
yachtsmanbill's Avatar
Must be a dodge ! Theres several 6 jolters on ebay... ws
http://motors.shop.ebay.com/i.html?_...506.m270.l1312
http://motors.shop.ebay.com/Parts-Ac...ts_Accessories
yachtsmanbill is offline   Reply With Quote
Old 02-20-2012, 11:57 PM   #4
[email protected]
Thanks
I've moved a lot of gas in my T. That's why I like the open top. But I've never tried to pump any. I'm afraid if I pumped I'd have a horrible mess to clean up.
OK so enough with the jokes. I don't believe I've ever heard of or seen a fuel pump on a model t. It's an interesting question though. Maybe it would come in handy on a steep hill and save having to run the tank full to get up a steep hill.
Have you tried doing a search on this site?
It's 110 miles to Chicago
We've got half a pack of cigarettes
It's dark
And we're wearing sunglasses
Let's go.
garrisonm89@yahoo.com is offline   Reply With Quote
Old 02-21-2012, 05:59 AM   #5
Steinar
Steinar's Avatar
Don't have to. We just back up the steep hill..
Steinar is offline   Reply With Quote
Old 02-21-2012, 06:17 AM   #6
gz
gz's Avatar
Keep in mind that early carburetors can handle very little pressure. Most electric fuel pumps made today are 4 psi or higher. Most older cars can handle 1 to 2 psi at the most, so you will also have to buy an adjustable regulator that will go down that low. If you need a 12 volt pump, those are easy to find. 6volt pumps will usually have to be special ordered but a good auto parts store can find one for you. I believe Snyders sells a 6v pump and I think Langs (Langs Old Car Parts, 1-800-872-7871) does as well. Good luck
gz is offline   Reply With Quote
Old 02-21-2012, 09:09 AM   #7
[email protected]
Well, Yah!!!
It's dark
Let's go.
Old 02-21-2012, 10:22 AM   #8
CharlieB
CharlieB's Avatar
Their available. They are sold in the big boy catalogs but can be bought locally. Check the other site for postings on this because I'm sure a pressure regulator is needed too. As stated above, the pressure is too high for T carb use.
CharlieB is offline   Reply With Quote
Old 02-21-2012, 10:45 AM   #9
Jalopy Tin
Here is a traditional solution. Hand primer pump and a vintage low pressure gauge.
http://www.ebay.com/itm/Fuel-pressur...item1e6b47c885
http://www.ebay.com/itm/VINTAGE-FUEL...item19cd473e30
Jalopy Tin is offline   Reply With Quote
Old 02-21-2012, 01:28 PM   #10
Layden B
If you only need it on the steep hills try this idea, it worked great for us. T off the gas line after your shut off valve under the tank. New line goes to fuel pump and then to another T close to the carb inlet. Yes you will be pumping in a circle but there will be higher pressure on the carb end and not so much as to flood the carb. Control the pump with a push switch so the pump only runs when you push the button as needed on steep hills. The rest of the time the flow will be gravity and you cannot " forget" and leave the pump on!
Layden B is offline   Reply With Quote
Old 03-02-2012, 09:38 AM   #11
allen
allen's Avatar
Send a message via ICQ to allen
Most four wheeler I work on has vacuum pumps less than 1 psi small and can be install in line
allen is offline   Reply With Quote
Old 03-14-2012, 05:21 PM   #12
mngreen
mngreen's Avatar
I did exactly this on my previous T when I lived at the top of a very steep hill. It worked great. The electric pump was from an old 6V VW beetle.
mngreen is offline   Reply With Quote
