Old 03-12-2024, 10:04 AM   #1
Mike1291
Mike1291's Avatar
Default What kind of contraption is this?
Found this odd looking water neck sifting through some parts in the garage. Looks like it was drilled and welded together many years ago. What do you think it did?
Early 1931 Coupe
Member of the Little Rhody Model A Club (MAFCA & MARC)
Mike1291 is offline   Reply With Quote
Old 03-12-2024, 10:10 AM   #2
mcgarrett
Default Re: What kind of contraption is this?
Looks like a barnyard attempt to add a heater. Gotta admire their resourcefulness by using what you have. "Poor folks have poor ways".
Old 03-12-2024, 10:12 AM   #3
JoeCB
JoeCB's Avatar
Someone working on a hot water heater set-up ???
Joe B
JoeCB is offline   Reply With Quote
Old 03-12-2024, 10:22 AM   #4
JayJay
Yup, that's a homemade takeoff for a coolant water heater, for sure. If you can find the engine that came from there is likely a similar connection for the heater return water on the lower gooseneck (left side of the engine block).
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 03-12-2024, 11:17 AM   #5
nkaminar
nkaminar's Avatar
It is for making a cup of instant coffee on the road. A faucet was attached. It was used back in the day when only water and ethanol (home brew) was put in the cooling system.
Old 03-12-2024, 12:24 PM   #6
Bob from Northport
Bob from Northport's Avatar
And you drank all the rust as well????????????????
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 03-12-2024, 12:57 PM   #7
J Franklin
J Franklin's Avatar
No need for iron supplements.
Old 03-12-2024, 01:21 PM   #8
Canton_Model_A's
Canton_Model_A's's Avatar
just make sure you put a filter in for brewing your coffee
1929 Model A Tudor
"Stay away from negative people, they have a problem for every solution"
Model A Ford Club of America
Model A Restorers Club
Motor City A's Club
Canton_Model_A's is offline   Reply With Quote
Old 03-12-2024, 03:04 PM   #9
Mike1291
Mike1291's Avatar
I agree that it was probably for a heater based on the history of the car. Though the sound of a hot coffee on the road does sound like a tempting take at an alternate history
Early 1931 Coupe
