Old 07-23-2021, 09:07 AM   #1
George V
Default What was it in its previous life?
Picked this up for a possible build. The frame is butchered up pretty good. It has a 9inch reared in it and a tube front axle. The work is crude at best.
George V is offline   Reply With Quote
Old 07-23-2021, 10:08 AM   #2
Kube
Kube's Avatar
Default Re: What was it in its previous life?
Looks like it was a 40 coupe at one point. Not much there worth saving I'm afraid.
Old 07-23-2021, 11:07 AM   #3
V8COOPMAN
V8COOPMAN's Avatar
Awe, c'mon man! We've all heard that YOU can make Chicken SALAD out of Chicken SCSHT! Well.......CAN'T YA? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-23-2021, 11:46 AM   #4
tubman
tubman's Avatar
"Not much there"; I agree, but what is there appears to be pretty solid. Up here in Minnesota, we'd find them rusted 6 inches up the body behind the doors.
Old 07-23-2021, 11:56 AM   #5
Tim Ayers
With the firewall cut out like that and a later rear, I wonder if was an old drag car that had the engine set back
Old 07-23-2021, 12:18 PM   #6
tomcarman
tomcarman's Avatar
I'm no expert but in my opinion it appears someone had it set up as a "Gasser". Given the extensive fire wall and floor pan surgeries, the straight tube front axle and rear end modifications it certainly fits the description.
tomcarman is offline   Reply With Quote
Old 07-23-2021, 12:34 PM   #7
tubman
tubman's Avatar
I think you guys are correct saying drag car, but from what I see, it was an attempt and never saw the track.
Old 07-23-2021, 12:58 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
Thousands of guys with 'dreams' of a race car like this one likely saved many thousands of these cars from going straight to the crusher. Typically, a guy like this found a clapped-out coupe that SHOULD have been destined for the crusher, until "Race Boy" acquired it, mounted his prized set of 'RACING' GAUGES in the dash, torched that huge firewall hole for the dreamed-of "gi-hugic race engine", as well as to save weight. Crammed-in that "racing" Ford rear end with Daddy's welder for the massive drag racing torque expected. Girls, and a newer Mustang changed the direction and the car was pushed right out there amongst the trees like you see it, thus saving one more coupe for us restorer-types to be able to piece back together from the dead. So, who still says that "Wanna Be" hot rodders are bad souls? That coupe that the kid inadvertently saved is in way better shape than Kube's avatar. DD
T5 W/TORQUE TUBE
Old 07-23-2021, 01:49 PM   #9
19Fordy
19Fordy's Avatar
V8: YOUR PHOTO OF THE 40 being demolished is painful.
Old 07-23-2021, 01:56 PM   #10
Ronnieroadster
Ronnieroadster's Avatar
Looking closely I can see traction bars on the rear axle a straight tube front axle tube shock absorbers in the front and a nice matched set of front tires. The dash has a very nice selection of gauges. This may have been a Hot Rod or a Gasser for drag racing. Body looks to be maybe 46 to 48 or?
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 07-24-2021, 12:33 PM   #11
34pickup
34pickup's Avatar
Looks like a LOT there worth saving to me.
Matt 24:36-41
34pickup is online now   Reply With Quote
Old 07-24-2021, 12:48 PM   #12
Ggmac
Ive saved MUCH worse . That isnt bad . But Im alot older now
Old 07-24-2021, 01:11 PM   #13
alanwoodieman
I pulled a former dirt track 40 coupe out of a ditch at the back of the old race car shop--looked a lot worse than that. took a few pictures of it to commerce swap meet and a lot of guys came up and cut repair panel off of it. cost my 40 for the tow and I sold over 300 in patch panels and still have the cowl, rear window section and a goo front crossmember-so yes there is a lot of good in that car
Old 07-24-2021, 04:56 PM   #14
46HARLEY
46HARLEY's Avatar
Yard art
46HARLEY is offline   Reply With Quote
Old 07-24-2021, 07:40 PM   #15
George V
Originally Posted by 46HARLEY View Post
Yard art
The rusty one next to it is the yard art for sure. Although it does have an unmolested frame under it.
Old 07-24-2021, 07:44 PM   #16
George V
It looks way worse than it is. Most of the panels are pretty solid. The window cranks are interesting. Never seen a hinged window crank. Heck the 9inch is worth a couple bucks. It came with a hood too.
File Type: jpeg 768A159E-F270-4A1D-9AF0-C6F5B03AF8D0.jpeg (123.5 KB, 14 views)
Old 07-24-2021, 07:49 PM   #17
George V
It saw the track I believe. It came from Kokomo, IN. US 41 Dragstrip is located there. When I was a kid I spent many a weekend at US 30 Dragstrip my brother in-law ran a 67 Camaro there.
Old 07-24-2021, 08:19 PM   #18
34pickup
34pickup's Avatar
Originally Posted by George V View Post
It looks way worse than it is. Most of the panels are pretty solid. The window cranks are interesting. Never seen a hinged window crank. Heck the 9inch is worth a couple bucks. It came with a good too.
Those window cranks came off of an early 50s Chrysler product.
Matt 24:36-41
Old 07-24-2021, 08:29 PM   #19
George V
Really. They are cool in my opinion. They still work like new. Not the window but the hinged cranks.
Old 07-24-2021, 08:43 PM   #20
George V
Thats what I was thinking also.
