10-16-2019, 04:59 PM | #1 |
55 crown Victoria hel0 needed
Im looking for help to ID a part. Im restoring a 55 ford crown Victoria and looking for a small exterior door trim piece. However i do not even know what it would be called let alone the fomoco part number or where to find it.
The piece is about 2×2inches and is just outside the door lock knob on the ext. door panel (below the side 'crown pillar' on the roof. Picture attached. Thanks in advance for any info u can provide. |
10-16-2019, 07:40 PM | #2 | |
Re: 55 crown Victoria hel0 needed
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
10-16-2019, 08:22 PM | #3 |
I have seen those in an ad. Reproduction part. Don't remember where since I didn't need them. Pretty pricey. If I can find the ad or the supplier I will post it.
Ben |
10-17-2019, 05:41 AM | #4 |
The part # for the left/driver side is B5A-6420189-A. It's called door outside rear upper corner molding.
Fits '55-'56 Crowns, Body style 64A and 64B (glass top & steel top). Maybe try searching by part number for a possible source. |
10-17-2019, 08:35 AM | #5 | |
Now, how did you do that?
10-17-2019, 10:51 AM | #6 |
10-17-2019, 07:06 PM | #7 |
10-17-2019, 04:28 PM | #8 |
10-17-2019, 11:40 PM | #9 | |
He sank my battleship ...
10-20-2019, 12:24 AM | #10 |
Here is a close up picture of that elusive small Trim Piece on the door, unique to the 1955 Ford Crown Victoria. |
10-17-2019, 05:18 PM | #11 |
10-17-2019, 11:38 PM | #12 |
Both you and I ...
10-17-2019, 03:53 PM | #13 | |
I found the door outside rear upper corner molding but the numbers I have are B5A 6421088/89 A Last edited by 56sedandelivery; 10-18-2019 at 10:15 AM. |
10-17-2019, 04:15 PM | #14 | |
88 will be RS and 89 LS.
05-17-2020, 08:05 AM | #15 |
05-17-2020, 08:51 AM | #16 |
I looked at the EBAY auction. Some people are crazy. I would rather make one out of steel and have it chrome plated, than pay $600 for a pair. Plus they are reproductions. Not even original. Greed really prevails here.
Sal |
05-19-2020, 07:54 AM | #17 |
I would think that is called the Barnum effect.
05-20-2020, 08:02 AM | #18 |
05-23-2020, 04:29 PM | #19 |
Don't use steel use brass. Easier to carve and drill for pin and the screw and brasss loves Chrome...
Some of the prices for this old car stuff is really beyond belief! And repros to boot! Hope they put them in this guy's coffin... |
12-01-2020, 04:34 AM | #20 |
Here are two photos of that Door Trim that you need for your 1955 Ford Crown Victoria. The top photo shows the door open while the lower photo shows the door closed. Hope that it helps. |
