Old 08-24-2022, 10:42 AM   #1
dono50
dono50's Avatar
Send a message via MSN to dono50
Arrow Replacing distributor wire on 49-51 flathead
I need to replace the hot wire that is located below the distributor plate on an 8BA 49-51 flathead.
Can this be accomplished without removing the plate ?
Your comments
dono50 is offline   Reply With Quote
Old 08-24-2022, 10:54 AM   #2
LuckyFordGuy
LuckyFordGuy's Avatar
Default Re: Replacing distributor wire on 49-51 flathead
Yes it can take the distributer out lots easier
LuckyFordGuy is offline   Reply With Quote
Old 08-24-2022, 12:21 PM   #3
dono50
dono50's Avatar
Thanks, LuckyForGuy. I have an intermittent electric problem and the wire is suspect.
Yes, will remove the distributor.
Old 08-24-2022, 06:01 PM   #4
Peterooster
Peterooster's Avatar
1950 f-1 I had same intermittent problem, removed distributor and replaced wire.Under close exam old wire had no faults. But problem went away. Pete
Peterooster is offline   Reply With Quote
Old 08-24-2022, 07:22 PM   #5
Merc Cruzer
Merc Cruzer's Avatar
When I bought my car, someone had removed the whole connector and replaced it with just a wire from the points to the coil. It never created an issue, so I didn't get around to replacing it with the correct bolt, spacer and nut until recently. These car are pretty forgiving.
Merc Cruzer is offline   Reply With Quote
Old 08-24-2022, 10:00 PM   #6
dono50
dono50's Avatar
How did you manage to get the wire under the plate without actually removing the plate.
Pretty clever above the plate setup.
Old 08-24-2022, 10:13 PM   #7
dono50
dono50's Avatar
Pete,
Did you replace the wire without removing the plate ? Did you use a string or wire to pull it through ?
Old 08-25-2022, 08:59 AM   #8
Merc Cruzer
Originally Posted by dono50 View Post
Pete,
The wire itself is pretty stiff. You can bend it in a half circle and thread it under the plate and around the shaft. Or you can just attache a string or small wire to the old one, when you are pulling it out and use that to pull the new one through. I did it on both of mine, once I found new wires.
On the distributor that had the single wire going over the top, I put it under the plate, while I was waiting to get the correct pieces. Take the screw out of the condenser and push it out of the way. You can turn the plate a littler, to move it, to get access to the wire, while you are threading it through.
Old 08-25-2022, 10:25 AM   #9
Merc Cruzer
Thought you might want to see the path you are taking under the plate. Also, you might want to see how much play, there is in the shaft. I wound up putting new bushing in both of my distributors. A local club member, had a Sun distributor machine, and when he put them on the machine you could see the bounce created by the loose shaft. I know it is a bit more work, but it truly pays of it's self. After replacing the bushings, the bounce was gone. The 2 bushing bushings, are not that expensive, and getting them out and installing new ones is really straight forward.
Bushings are $15 for a set:
https://www.ebay.com/itm/25482385155...&segname=11050
Old 08-25-2022, 10:28 AM   #10
dono50
dono50's Avatar
Thanks for the photos and advise. My primary wire must be a replacement because the routing is different so not correct.
I bought NORS wires and should be fine. Thanks again
Old 08-25-2022, 10:39 AM   #11
dono50
dono50's Avatar
I’ll check the bushings when I remove the distributor. My wire made by Standard your NOS Ford same as original
Old 08-25-2022, 10:09 PM   #12
dono50
dono50's Avatar
Repaired my distributor and a spare. Runs great now. Your photos made it an easy task.
Had a 53 Merc Monterey 2 door hardtop back in the early 60’s sixties. My 50 Ford has a low mileage 49 Merc engine.
Old 08-26-2022, 06:58 AM   #13
Merc Cruzer
I too, did mine and a spare (picture taken before I got the wire connector). Then had both checked on a Sun Distributor machine, and he corrected the springs. Runs better than it ever has before.
Glad I could help, enjoy the ride.
Old 08-26-2022, 08:58 AM   #14
dono50
dono50's Avatar
I know a rebuilder online and will check if he has a sun distributor machine.
Thanks again
