02-12-2019, 01:28 PM | #1 |
Tubeless 16" tires
Would tubeless 16" radial tires work on 1935 Ford rims?
AL in NY Last edited by AL in NY; 02-12-2019 at 02:08 PM. |
02-12-2019, 01:44 PM | #2 |
Re: Tubeless 16" tires
No,
1932 Model B and V8 used a 18" rim. \ 1933-34 V8 and Model B used 17" rim The 16" spoke rim was 1935 only |
02-12-2019, 02:15 PM | #3 |
Yes you can use tubeless on 16 in 1935 Ford wheels.
02-12-2019, 02:59 PM | #4 |
Yes but I would use Radial tubes. I would not go tubeless with those wheels.
02-12-2019, 04:10 PM | #5 |
Mine have been tubeless for 6 years. I add air once a year. Never had a problem with them.
Cowtown A's |
02-12-2019, 05:03 PM | #6 |
02-12-2019, 06:43 PM | #7 |
works on all four of mine, no issues
02-12-2019, 07:51 PM | #8 |
Yes, I have two Model A s and both have Bridgestone Ecopias . They are LRR which gives you a excellent ride and easier steering. I have over 20,000 miles on one set and not much wear. The old 21 inch bias ply would barely make 10,000 miles and they would be worn out . I used three sets of them and biasply are not cheap. I believe the size is 185/80,16 and 28 inches in diameter but would have to verify that when I get home. The tires are for electric car use only. I emailed Bridgestone and gave them the weight and speed of the Model A and said they would be fine and not a problem.
02-12-2019, 08:57 PM | #9 |
Bruce. I have those same tires. What air pressure do you run in yours.
02-12-2019, 11:31 PM | #10 |
I run at 32lbs and it handles well .I have them on my29 Hardtop pickup and on a 29 Business Coupe
02-13-2019, 02:02 PM | #11 |
Bruce/Guys, thanks for the feedback. I've been toying with the idea for 16" rims with radials, but wanted to be sure I could run them tubeless. Now the search is on for four 16" rims. I did see a really nice set of 15" rims for a 33-66 Mopar that has the same bolt pattern. I have to check and see if they will work on Model A brake drums.
AL in NY |
02-13-2019, 02:28 PM | #12 | |
As stated, in answer to you OP, yes they will work ! However, depending on the condition of your wire 16" rims, you should consider using 'radial tubes' with your radial tires. I have always 'prepared' the center of wire rims to prevent any chaffing of tubes, if used. I have a set of Coker steel belted radials on wire rims (KH) for many years now. I installed the Coker radial tubes recommended and have lost only a few pounds of air a year from each. I maintain 32 lbs and ride/steering is great ! One thing that I recommend is the Coker tube stem 'protector". Wonderful/cheap insurance against rim chaffing the tube stem. |
02-13-2019, 02:51 PM | #13 | |
Charlie Stephens |
02-13-2019, 07:50 PM | #14 |
Al ,I would stick with the 16 inch .The Bridgestone tire is very close to the Model a tire in outside diameter and it is probably 2 ply sidewalls. They would be perfect for your F150 overdrive so you can keep your speed up.You will find perfect rims,just keep looking.
02-13-2019, 09:22 PM | #15 |
Ford 16" wire rims are welded spokes,use a decent valve stem and run tubeless
Kelsey Hayes 16" wire rims are true spokes that anchor inside the rim,use tubes and flaps Kelsey Hayes Ford |
02-13-2019, 08:55 PM | #16 |
Been running 16" modern Tubeless radials on 1935 16" rims on blue coupe for over three years now. Befor that the same tires and wheels were on my speedster - first installed in 2008. woe it has been ten years. Yes, I know it is time for new tires. The tread is stilll good but the sidewalls are beginning to crack.
The tires are Dunlop 215 70R 16. The new tires - sometime this spring -will be either Goodyear or Dunlop -same size. Its IMPORTANT. Make sure there are no rough spots, barbs, scratchy thingees on the inside of the rim, expecially at the spoke weld joints. I took a die grinder and polished the inside of each of the four rims. |
02-13-2019, 09:22 PM | #17 |
yes you can. I put 16" Good Years on Glorrian Nau`s tudor years ago and they drove it to Loveland, with know problems
02-14-2019, 08:01 AM | #18 |
Nice pictures and explanation, railcar. thanks.
02-14-2019, 08:42 PM | #19 |
nice set on facebook marketplace..4 1935 for wires with coker classics and hubcaps for 650 bucks.
02-15-2019, 03:28 PM | #20 |
Railcarmover, I don't know much about Facebook Marketplace. Could you post a link or the sellers cont6act information?
AL in NY |
