Old 09-23-2021, 03:04 PM   #1
griffin
Default Champion 3x electrode
Looking at my 1st set of 3x plugs, it appears the side electrode points to the side of the center electrode, not hover over the top as most other plugs do.
Am I correct or am I looking at plugs somebody has gotten their mileage out of? Another issue that appears to me is the corrosion on the body of the plug. I have no idea the age of these plugs. These are flat-top 3 plugs.
My plugs are gapped at .045, which is obviously waaaayy too much.
I'm not going to reuse these plugs, just curious how the electrodes are supposed to be positioned.
griffin is offline   Reply With Quote
Old 09-23-2021, 03:35 PM   #2
Werner
Werner's Avatar
Default Re: Champion 3x electrode
Griffin,
this is an ancient spark plug like the one used in the past. Collectible. Nowadays the ground electrode sits above the middle electrode.
btw.: Modern iridium spark plugs are recommended.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 09-23-2021, 04:43 PM   #3
AL in NY
AL in NY's Avatar
The 3X plugs are the best plugs (IMHO) for the Model A. They can be gapped on the side of the electrode with no performance problems. Remember, this is a very low compression, low HP engine.
AL in NY
AL in NY is offline   Reply With Quote
Old 09-23-2021, 05:18 PM   #4
woofa.express
woofa.express's Avatar
This is perhaps some worthless information for you Al.
I remember the negative electrodes on early aviation sparkplugs. Like one in the picture below but two opposing platinum wires. The second picture is a modern aviation spark plug using plug electrodes which is probably the only type available on today’s market. pictures from the internet.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 09-23-2021, 07:20 PM   #5
mercman from oz
mercman from oz's Avatar
I think that it needs replacing?
Old 09-23-2021, 07:33 PM   #6
nkaminar
nkaminar's Avatar
The plugs were made that way so that any oil or liquid gasoline (remember that gasoline was at one time close to kerosene) would drip off the electrodes to clear them.
Years ago there was a machine that was used to sandblast plugs to clean them up. You may try that on these plugs. You can just use a blast cabinet.
Old 09-23-2021, 11:45 PM   #7
J Franklin
J Franklin's Avatar
Those too young won't remember rebuilt spark plugs, with new electrodes welded on to replace the worn ones. Things were rebuilt in the golden years. Maybe those still have some life.
Old 09-24-2021, 10:38 AM   #8
katy
katy's Avatar
Just set the gap at .035", put them back in and go.
Old 09-24-2021, 01:10 PM   #9
Werner
Werner's Avatar
I thought such little things were only repaired in the poor times in Germany.
Here are some interesting things from my old spark plug collection. There were also spark plugs that could be dismantled, new seals and a new insulated center electrode were put in.
Repaired spark plugs were embossed and stamped with "Repariert" and the name of the repair company
Werner
Citroen 11 CV, 1947
Old 09-24-2021, 03:13 PM   #10
Kurt in NJ
Kurt in NJ's Avatar
One of the ways to change the gap is to loosen the nut holding the ceramic and rotate to less worn area of center electrode
Old 09-24-2021, 04:33 PM   #11
Gene F
Gene F's Avatar
Anyone ever use those E-3 spark plugs before?
Old 09-24-2021, 05:31 PM   #12
woofa.express
Some more worthless information for you.
It doesn’t seem so long ago, but probably 30 years, when aviation fuel (avgas) had a lead component. At a 100hly service it was necessary to remove lead in the upper reach of the ceramic insulating cylinder. One could purchase a special cleaning tool but I used to use a disused hacksaw blade which I had ground down on a bench grinder to a blunt point with a reach of about 1 and quarter inch. This was followed by a clean on a spark plug cleaner. I didn’t put platinum electrode plugs on a cleaner.
I know many things,
Old 09-24-2021, 05:42 PM   #13
Utopia Texas
Utopia Texas's Avatar
Snyder’s sells a replacement base for the 3X.
Utopia Texas is offline   Reply With Quote
Old 09-24-2021, 11:26 PM   #14
1930artdeco
1930artdeco's Avatar
How does one rebuild the 3X plugs? I have a set that were acting up so I want to clean and rebuild them. Where does one get new seals for them?
Thanks,
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 09-25-2021, 01:55 PM   #15
Brad in Germany
Brad in Germany's Avatar
Hi Werner,
FWIW, according to era Bosch documents, the original spark plugs for German assembled Model A's for 1928-1930 are the BOSCH DZ 20/3 (detachable) or BOSCH Z 20/3 (non-detachable).
For 1931 (and newer), according to era Ford and Bosch documents, original spark plugs for German built Model A's are the BOSCH DZ 45/1 (detachable) or the BOSCH Z 45/1 (non-detachable).
Brad in Maryland
Brad in Germany is offline   Reply With Quote
Old 09-25-2021, 04:10 PM   #16
Werner
Werner's Avatar
Guten Abend Brad,
thanks for nice informations! It's looking good.
Werner
Citroen 11 CV, 1947
Old 12-06-2021, 10:21 PM   #17
PinoleMike
I have the same plugs in my 1929 Town Sedan. They were in it when I purchased it 8 years ago. This thread has answered many of my questions. Thanks guys!
PinoleMike is offline   Reply With Quote
Old 12-06-2021, 11:37 PM   #18
Gary WA
Gary WA's Avatar
Thanks,
Mike
Take them apart and clean them,Bead blast base interior only, not ceramic part. There is a very thin washer between ceramic and base,!http://modelabasics.com/3xplug.htm seals only one are usually good .
www.whidbeymodelaclub.com
Old 12-06-2021, 11:49 PM   #19
J Franklin
J Franklin's Avatar
Thanks,
Mike
I ran accross this post with good info.
https://modeltfordfix.com/cleaning-t...rk-plug-t1386/
Old 12-07-2021, 10:55 AM   #20
katy
katy's Avatar
Does it get driven much?
