Originally Posted by modelanut
Thank you. The first picture from Chris Haynes shows the two eccentrics about 2/3 of the way up on the backing plate but the parts blowup does not. I will call the references. I appreciate the help. It's time to get my high school ride moving again.
They are not shown as they part of the backing plates and serviced separately.
Only way to get the cams is to salvage them off another plate; or switch plates.
Only one bad I would fix it; but if both are twisted off; I would probably replace the plate, unless the existing plate was powder coated or plated.
They are in the parts blowup tho; circled them.
