01-15-2022, 10:23 PM | #1 |
Installing windshield glass 46 ford
When installihg rubber back into windshield frame I put a long piece of string into groove where the rubber slips back onto the window frame,correct?? When rubber is installed onto car,pull string and this pulls the rubber into place,no sections folded under. Am I looking at this correctly. Thanks!!
01-15-2022, 10:31 PM | #2 |
Re: Installing windshield glass 46 ford
somewhat correct, it is better with at least two people, place window on the inside and pull string to outside, use soapy water for a lubricant, be sure the string crosses over itself so you can make sure it is long enough
01-15-2022, 10:40 PM | #3 |
Thanks, I understand soapy water or detergent on actual window or groofe glass fits in,didnt know I would need it to get rubber on car itself or window frame.
01-15-2022, 10:50 PM | #4 |
This shows and tells how to install 1946 Ford windshield.
http://www.vanpeltsales.com/FH_web/f...-40-46_pg1.htm |
01-16-2022, 11:13 AM | #5 |
I agree with Alan... two people make the task much easier. I use glass cleaner (spray) as it won't bubble up when it gets wet later on.
Make sure you end at a corner of the glass with the nylon line. That's the strongest place.
01-16-2022, 12:22 PM | #6 |
01-16-2022, 01:07 PM | #7 |
years ago i helped a good friend of mine put a windshield in his old chevy someone told him to use dish soap so we did put it in the rubber gasket all around worked great except for when it rained hard when driving he had enough bubbles to wash his car and the one behind him
Thread Tools | |
Display Modes | |
