11-28-2023, 10:53 AM | #1 |
88 Ford Ranger
Old Rusty, as my wife calls it, is my plow truck here in Mi. Runs good for a 400 $ truck, except when it warms up. Its wierd, sometimes, not always, has a big bog when stepping on the gas, then quits, starts right back up and runs good for a minute or two, then does it again. I changed the in tank fuel pump, air valve for the intake, plugs, wires. It's a 2300 4cyl. any thoughts?
11-28-2023, 12:10 PM | #2 |
Re: 88 Ford Ranger
Have you ever replaced the fuel filter ? Coud be the problem.
Sal |
11-28-2023, 12:10 PM | #3 | |
Re: 88 Ford Ranger
AIR VALVE (?)
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - |
11-28-2023, 12:54 PM | #4 |
Re: 88 Ford Ranger
EFI, air valve, its attached to the air cleaner housing, "idle air valve"? sorry not up on EFI stuff, give a carb any day.
11-28-2023, 12:58 PM | #5 |
Re: 88 Ford Ranger
11-28-2023, 01:02 PM | #6 |
Re: 88 Ford Ranger
11-28-2023, 03:34 PM | #7 |
Re: 88 Ford Ranger
thanks guys for the help
11-28-2023, 06:02 PM | #8 | |
Re: 88 Ford Ranger
Have you checked the fuel pressure when this happens ? If I remember right it should be 32 PSI with the vacuum line on the regulator at idle, and 40 PSI with the vacuum line disconnected at the regulator (simulating wide open throttle). Maybe scan the procesor for trouble codes too. Sal |
11-28-2023, 06:17 PM | #9 |
Re: 88 Ford Ranger
It sounds to me ... ... as once it comes off the enrichment circuit (cold start), she goes lean.
I am a$$-u-me(ing) it is an EFI SYSTEM with a SGL THROAT THROTTLE BODY. It is EEC-IV OBD-II. The ECM needs to be scanned for any possible code(s). Did you have a fuel pressure gauge when replacing the pump? It idles fine at cold start but when the fast idle comes down she stutters? Is the throttle body carboned up? There is also an IAC (IDLE AIR CONTROL) MOTOR on the side of the TB that will get gummed up as the PCV SYSTEM unloads there. Then you also have a COOLANT TEMP SENSOR that goes because the coolant is never changed and an AIR INLET TEMP SENSOR. You can scan the ECM manually if you have the patience.
11-28-2023, 07:07 PM | #10 |
Re: 88 Ford Ranger
now you have overloaded me with info. Thanks I will see what i can figure out. On this one the idle air control is by the air cleaner, and i replaced that, seemed to help for a week or so then back to the same thing. I guess i should drive it more, but its not road worthy and it hardly snows here any more. ha ha
11-28-2023, 07:10 PM | #11 |
Re: 88 Ford Ranger
If I'm not mistaken, '88 was the last year for carburators before EFI took over in '89. Sounds to me like junk in the gas tank is bunching up around the sock and starving out the carb for gas, but once it is shut off, there's no more suction and the junk falls off around the sock, so the engine can start again, for a little while until the situation repeats itself. Either that or clogged fuel filter.
For refernece, I use those cheap clear-plastic inline fuel filters in both my jalopies and they never last longer than one year, even though I don't run them much anymore. |
11-28-2023, 07:54 PM | #12 | |
Re: 88 Ford Ranger
11-28-2023, 07:56 PM | #13 |
Re: 88 Ford Ranger
It is EFI, correct? This year had two pumps, one a transfer pump in the tank and the other, the high pressure pump on the rail.
Could also be a vacuum leak, EGR VALVE or possibly a fuel pressure regulator. You actually need a FORD WSM to go through the DIAGNOSTIC ROUTINE before dumping any more $$$ on it.
11-28-2023, 08:39 PM | #14 |
Re: 88 Ford Ranger
If it is an '88, 2.3 it's a DOHC engine with a plastic intake manifold. The manifolds did crack, creating a vac leak, that usually won't throw trouble code. Sometimes you can find a vac leak with carb cleaner spray, just stay clear of the ignition system
11-29-2023, 01:18 PM | #15 | |
Re: 88 Ford Ranger
This one is a 2.3L EFI, and yes the IAC was mounted to the air cleaner box with a hose going to the throttle body. Sal |
11-29-2023, 07:03 PM | #16 |
Re: 88 Ford Ranger
Yes, thats the one. when i mess with the IAC hose by taking it partial off the thing runs nice. thats why i replaced the IAC. but that was not the permanent fix, but makes me think i am on the right track.
11-29-2023, 07:04 PM | #17 |
Re: 88 Ford Ranger
11-29-2023, 07:05 PM | #18 | |
Re: 88 Ford Ranger
R U able to take and post photos? I surely would like to see how the engine is setup.
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - Last edited by KULTULZ; 11-29-2023 at 07:20 PM. Reason: THE USUALY - ADVANCED CRS |
11-29-2023, 09:23 PM | #19 |
Re: 88 Ford Ranger
I am able to take pictures with my phone, but posting dont work for me. sorry
11-30-2023, 03:43 AM | #20 |
Re: 88 Ford Ranger
THANX! for trying ...
