Old 05-26-2020, 02:25 PM   #1
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Default Who owns a floor vent, manifold heater?
I saved these pictures, several years ago.
I don't remember whose car it was.
Do any of own a vehicle with a floor vent, manifold heater?
I have everything but the manifold cover.
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 05-26-2020, 07:18 PM   #2
hop up
hop up's Avatar
Default Re: Who owns a floor vent, manifold heater?
I have a Arvin cover for one but they came in many configurations. So not sure if it would fit your application..
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
Old 05-26-2020, 07:23 PM   #3
jw hash
jw hash's Avatar
Neil I don`t have one like that but I have been lucky enough to find two floor vent type as pictured. I put one in my 160 A and it will run you out of there. i like having the vent go through in the wood, so no hole in the firewall. I have a flier on this manifold somewhere here but there is no brand name on it.
jw hash is offline   Reply With Quote
Old 05-27-2020, 09:53 AM   #4
katy
katy's Avatar
[QUOTEI have everything but the manifold cover.][/QUOTE]
If you have the manifold it shouldn't be hard to fabricate a cover.
Old 05-27-2020, 02:43 PM   #5
I have a stock manifold, so I need to fabricate a cover that will sit on the manifold and connect to the pieces coming up from the floor.
Old 05-27-2020, 07:12 PM   #6
hop up
hop up's Avatar
On the label it kinda shows how it goes and it’s pretty cool and amazing how it survived as a water slide decal . The dimensions are 17.5 inches long with a depth of 3.5 inches and is 4.5 inches tall. The inside mounting bolts are 14 inches apart center line. My apologies as I am a V8er and cant measure on a 4cy motor.
Old 05-27-2020, 07:17 PM   #7
hop up
hop up's Avatar
Backside of cover. Also I believe a fellow Fordbarn member worked at the factory and may have more inside info on the heater vent Neil has and this cover..
Old 05-28-2020, 09:59 AM   #8
Bob Bidonde
Bob Bidonde's Avatar
The photo shows a reproduction of a hot air floor heater that is in my Coupe. It has poor air flow, so not much heat gets into the car. I will be adding an electric fan into the system to force air flow.
File Type: jpg Hot Air Heater w Floor Register 429 kb.jpg (85.3 KB, 45 views)
Bob Bidonde
Old 05-28-2020, 10:40 AM   #9
katy
katy's Avatar
[QUOTEI] have a stock manifold,[/QUOTE]
A lot of the "manifold heaters" used a special exhaust manifold, some w/fins, to radiate heat.
In your first post you said "I have everything but the manifold cover." so I assumed that you had an aftermarket manifold.
Old 05-28-2020, 01:17 PM   #10
Hop up,
I would like to buy your Arvin cover.
I sent you a PM.
