Old 02-29-2020, 11:39 AM   #1
Michael_Velling
Default Leaking Head bolt?
Hello, i am Michael from Germany and new to Model A. My other car is a Model T
Yesterday i changed oil and put a stoneguard on my car. After that i started the engine and it runs. Before that i cleaned the head and so on. After a while i found some fluid around a head bolt near the distributor.
Any idea what this is? Where is the defect?
Thanks a lot
Michael
Michael_Velling is offline   Reply With Quote
Old 02-29-2020, 11:54 AM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Leaking Head bolt?
I would drain the coolant , remove the leaking stud and cover the stud threads that enter the block with silicone sealer and reinstall the stud and head nut . check and retorque the head nuts .
Old 02-29-2020, 12:11 PM   #3
Michael_Velling
Okay, is it not better to remove the head for this?
Old 02-29-2020, 01:01 PM   #4
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
You will have a difficult or impossible time with the head on. You must remove the head to remove the stud.
Dick M is offline   Reply With Quote
Old 02-29-2020, 01:02 PM   #5
Jim Brierley
Head removal may not be not necessary, but be careful as studs break quite easily. You might first try just removing the nut and silicone only under it. Congratulations on stepping up from that old Ford to a new car, the Model A! :-) What part of Germany do you live in? I was stationed in Nurnberg in 1961-62, and loved it.
Old 02-29-2020, 03:00 PM   #6
1931 flamingo
1931 flamingo's Avatar
Try re-torqueing the nut, probably wouldn't hurt to do all of them. JMO
Paul in CT
Old 02-29-2020, 04:13 PM   #7
Purdy Swoft
Sometimes the stud backs out when the head nut is removed . The head may have to be removed but one thing for sure is the stud will usually need be removed . In many cases the bottom will be knocked out of the stud hole in the block , caused from over tightening the stud . If this is the case , the only fix that I know of would be to seal the threads by what ever method possible . The stud could be backed out with vise grips but the upper stud fine threads would be damaged . I would seal the threads and install a new or used stud . For good measure when I first cranked the engine I would use a quality block sealer with tap water . I would follow the block sealer instructions to the letter . After the engine was run , cooled and drained I would install antifreeze and water to the ratio needed to protect from freezing . No matter what method is used , removing the head or not , when the stud is removed , there will be a risk of the stud breaking off in the block . Broken studs can be drilled and removed without damaging the block threads if care is taken .
Old 02-29-2020, 04:31 PM   #8
dansluck
Send a message via AIM to dansluck Send a message via Yahoo to dansluck
Hi Michael , Has the head been welded? I believe it might have been from the photo.
Dan
dansluck is offline   Reply With Quote
Old 02-29-2020, 04:48 PM   #9
Bill Lee/Virginia
Jim: I was stationed in Nurnberg, Merrill Barracks, with the 3d Armd Cav Regt in 56-57-58. Loved it too. Bill Lee.Virginia
Bill Lee/Virginia is offline   Reply With Quote
Old 02-29-2020, 05:10 PM   #10
Synchro909
Synchro909's Avatar
Twice, I've had a leak like that and neither time did I even consider removing the head. I simply added a little stop leak to the cooling system and within a short time, the leak stopped. I'll look further into it if I ever have to remove the head. It's already been about 40,000 miles on one engine.
Keep it simple, I say.
Old 02-29-2020, 06:13 PM   #11
barkleydave
barkleydave's Avatar
I have a stud puller which works most of the time. Pull stud put some red seal on threads and back down it goes. Also stop leak will help.
barkleydave is offline   Reply With Quote
Old 02-29-2020, 09:23 PM   #12
Gold Digger
I would try removing the nut and use a lead washer under it and put in some stop leak.
Gold Digger is offline   Reply With Quote
Old 02-29-2020, 09:48 PM   #13
dbaldwi3
dbaldwi3's Avatar
Stationed there 79-80 good times then transferred to bitburg.
dbaldwi3 is offline   Reply With Quote
Old 03-01-2020, 07:39 AM   #14
Michael_Velling
Hello to everybody, thanks for all your advices.
For the questions wich part in Germany. We live near Duesseldorf at the dutch border.
Have anyone a picture from the top of the engine with the head removed? I would like to see what is in this area, where the leak is. I think it us more than sealing the stud?
There must be some waterchamber where the fkuid coolant is from.
Michael
Old 03-01-2020, 07:51 AM   #15
1crosscut
1crosscut's Avatar
Attempting to remove a stud with the head in place in my opinion is a disaster just waiting to happen.
Torque all of the head nuts to 55 lbs. Add a stop leak product and run it for a while to see if it stops leaking.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 03-01-2020, 12:52 PM   #16
katy
katy's Avatar
Huh?
