Old 01-23-2020, 07:56 PM   #1
Kube
Kube's Avatar
Default pre-bent brake line kit - 39/40 Ford quality
Someone had fairly recently asked me how the pre-bent brake line kits are for '39 / '40 Fords. Unfortunately, I can't recall who...
The kits do come with pre-bent lines as the advertising states. However, they must be bent to fit a '66 Chevelle or something as they are not even close to proper for a '39 / '40 Ford.
Total waste of money.
The kit I'd purchased C&G and as I recall was around $150.
Yes, I have extremely nice authentic lines to compare.
No, I did not call C&G. They should be ashamed...
Old 01-23-2020, 08:34 PM   #2
35fordtn
35fordtn's Avatar
Default Re: pre-bent brake line kit - 39/40 Ford quality
Mike,
Jerry Grayson used to make the kits for C&G his were very good fitting pre bent lines and what were installed on my 40; unfortunately Jerry passed away sometime ago and his fixtures he sold off long before he died.. I do not know who acquired them. . In recent years I "Believe" they are selling Classic tube brand lines. I bought a set direct from Classic Tube for a 1946. They wound up in my dumpster and I made my own. They looked promising as they had the proper armor springs but were nowhere close. I have a large stash now of the armor springs if you need any.
35fordtn is offline   Reply With Quote
Old 01-23-2020, 09:05 PM   #3
Charlie Stephens
Please call C&G. If they are getting defective/substandard parts from their suppliers they need to know it or the rest of us will be next. Let us know their response, that is the important part.
Charlie Stephens
Old 01-23-2020, 09:25 PM   #4
philipswanson
I went with Classic Tube. Fit great, with very little hand forming except where the straight runs were too long to fit in the boxes. In those cases, it was easy to straighten them out. I bought stainless for my '40 wagon. Mild steel is also available. It came with all the correct shielding, hold down brackets, fittings, etc. A pleasure to install.
https://classictube.com/
I would never go to C&G for anything and they are in my backyard. All they do is supply Carpenter and Drake stuff.
philipswanson is offline   Reply With Quote
Old 01-24-2020, 09:53 AM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
At one time the Early Ford Garage, in Covina, California (Richard Lacy & Son), sold preformed hydraulic brake lines (probably not inexpensive) for early Ford V-8's, that could be purchased separately, or with their hydraulic brake conversion kits. Not sure what they sell, and have available today.
John
Old 01-24-2020, 09:59 AM   #6
Tim Ayers
Originally Posted by 35fordtn View Post
Mike,
Interesting. The armor springs go on the bends near the wheels, correct?
My list of things I need from you keeps getting longer with each post you make. Haha.
Old 01-24-2020, 10:19 AM   #7
19Fordy
19Fordy's Avatar
Correct. Here's a photo of 1940 OEM armor springs.
Old 01-24-2020, 10:36 AM   #8
Ken/Alabama
Ken/Alabama's Avatar
Thanks for the feedback. I had asked you about pre-bent brake lines with the armor springs.
Ken/Alabama is offline   Reply With Quote
Old 01-24-2020, 10:46 AM   #9
5851a
Probably 30 years ago I bought a coil of that brake line armor from a GM dealer. Can't remember the part #, it was maybe 25' in a small box. Maybe a person can still get it.
5851a is offline   Reply With Quote
Old 01-24-2020, 10:52 AM   #10
Tim Ayers
Thank you.
Old 01-24-2020, 11:04 AM   #11
CA Victoria
CA Victoria's Avatar
To tag onto mikes post....
To make your own lines is not expensive & pretty straight forward. ESP if you are replacing your system.
I replaced all of the lines on my F1. After a few times making practice double flares yours will look like a machine made fitting.
Although I bought the double flare tool, Napa had one to loan out. I had an inexpensive swap meet tubing bender but for small steel lines having an assortment of pvc to bend a radius around is all that’s needed.
A number of sources sell the steel line and fittings in a kit for under 40 bucks.
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 01-24-2020, 11:17 AM   #12
35fordtn
35fordtn's Avatar
Exactly, very cheap to make on your own. Attached is photos of the armor on some NOS Ford lines I have. I also have 3600 feet of cadmium plated armor here if anyone needs any... it would be priced pretty cheap.
Old 01-24-2020, 06:10 PM   #13
Kube
Kube's Avatar
Guys, I have made more sets of lines than I can recall properly. I know how to double flair and bend.
At the time I needed the last set of lines, I was unable to get a set of straight lines - the typical out of stock routine.
As I didn't realize I could purchase the armor, I took a chance on the pre-bent lines.
So, I have learned two things during this debacle. 1) the pre-bent lines are obviously not pre-bent to fit a '40 Ford. And 2) I can purchase armor.
Old 01-24-2020, 06:11 PM   #14
35fordtn
35fordtn's Avatar
Mike do you use stainless or steel lines?
Old 01-24-2020, 06:21 PM   #15
KiWinUS
KiWinUS's Avatar
Looks like steel as you should not double flare stainless.
Old 01-24-2020, 07:08 PM   #16
35fordtn
35fordtn's Avatar
I’ve not used stainless lines before. Didn’t know you can’t double flare them! Learned something new to me that’s likely basic knowledge, and perfect timing as I was about to order stainless lines to bend some up for a project...
Old 01-24-2020, 07:26 PM   #17
KiWinUS
KiWinUS's Avatar
Stainless is all we use on our race cars. It will split if you double flare it. BBR racing solutions here in Charlotte can scan a line & the bend per the scan. We use female nuts with a backer the screw onto male AN fittings but I’m sure they could use regular male brake line nuts. I could ask the owner when I return from NZ as he is a friend of mine.
Old 01-24-2020, 07:32 PM   #18
Kube
Kube's Avatar
steel.
Old 01-24-2020, 07:39 PM   #19
95476
95476's Avatar
Mike, Maybe you can list some of that armor on EBAY.
I just did a set of line without the armor but would like to make a few sets of '34 lines using Richard Lacy's as patterns.
95476 is offline   Reply With Quote
Old 01-24-2020, 11:20 PM   #20
Tinker
Tinker's Avatar
Does Lacy not do them anymore? Mine were super nice with all the spring rock guards were the lines were exposed to the road (39). All hardware also, can't remember the cost but remember it all fit well.
