03-25-2014, 01:39 PM | #1 |
Spun Bearing ???
What is the cause, and what is a proper fix ???
I've recently had an 8BA come to me with a spun rod bearing. All the other bearings look ok. |
03-25-2014, 02:09 PM | #2 | |
Re: Spun Bearing ???
1-An involved tolerance was out of spec. 2-Abuse. The fix is, mag and measure the crank to see if it can be saved. If ok, grind to next undersize. Get a pair of NEW rods. Don't try to recondition a rod that has had a spun bearing. Re-balance all parts. |
03-25-2014, 04:12 PM | #3 |
You mean like this?
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
03-25-2014, 04:23 PM | #4 |
Crankshaft needs plugs pulled and cleaned out?
Lonnie |
03-25-2014, 04:54 PM | #5 |
03-25-2014, 05:40 PM | #6 |
Pete has given sound response. R |
03-25-2014, 08:28 PM | #7 |
Also, I believe if the cause is #2..abuse in Pete's explanation above, the crank could be bent.
Dick. |
