Here is a real nice completely restored 1941-47 ford truck instrument cluster, it is a rare 60 mph speedometer with the shift points. All four of the gauges are n.o.s are all checked and tested with original faces, the speedometer was completely rebuilt and lubricated with new face and odometer numbers applied and the speedometer was run up to make sure everything worked and it did. The inside of the case was repainted and clearcoated and outside was bead blasted and clearcoated, has a new seal and and bezel was repainted, the inner face has also been media blasted and repainted. Don't believe you will find one any better. $425.00 plus shipping. I also have 1940 car and 1941-47 truck and pickup clusters available.
