01-28-2021, 08:46 PM | #1 |
Headlight questions 46 Ford
Ok, I have new headlight harness and dimmer switch. Headlights only work low beam UNLESS I switch wires around on the headlights, then lights only work high beam. Have I miswired the dimmer switch? Thanks
01-28-2021, 08:58 PM | #2 |
Re: Headlight questions 46 Ford
Here is a picture of the dimmer switch in my '46 Coupe, and a wiring diagram.
01-28-2021, 09:40 PM | #3 |
You might have the ground wire on the lights on the wrong terminal. Way back when, I had the same problem and I had the bubs wired incorrectly.
01-28-2021, 09:46 PM | #4 |
