Old 03-31-2020, 02:34 PM   #1
First time restorer
Default Quarter window seal
Has anyone had a problem with replacement seals for my quarter windows on my 1939 4 door deluxe being to big? I bought the seals from Dennis Carpenter
Last edited by First time restorer; 03-31-2020 at 02:44 PM. Reason: Forget to say what car I was working on
First time restorer is offline   Reply With Quote
Old 03-31-2020, 03:15 PM   #2
Karl Wescott
Karl Wescott's Avatar
Default Re: Quarter window seal
Hello
What part number did you order/get from DC?
If you are trying to use the 78-7029904 1 piece seals, those are for a coupe, not a fordor. You will need the 10' length of seal and cut to length, or cut down the 1 piece seals.
I am assuming the cross section of the rubber channel is OK, Is that correct?
Karl Wescott is offline   Reply With Quote
Old 04-01-2020, 08:06 AM   #3
alanwoodieman
do you have the flip out window?
Old 04-01-2020, 09:50 AM   #4
First time restorer
Yes, on a 39 fordor
Old 04-01-2020, 10:21 AM   #5
TJ
TJ's Avatar
Have you talked to Carpenter about the issue? Those seals should be the same as a '40. Some time back I did a '40 fordor and used the Drake seals. They fit perfect. The Drake part # is 81A-735139/1 and fit the 38-40 tip out style quarter window on a fordor sedan.
Old 04-01-2020, 11:31 AM   #6
Kube
Kube's Avatar
I have never installed a set of 1/4 seals in a fordor. I have however, attempted to install rear windshield seals (coupe) from Carpenter and they are way too big. Drake's fit perfectly.
I only state this as the possibility surely exists that the 1/4 seals are also too long.
Old 04-01-2020, 02:38 PM   #7
Hal Beatty
Hal Beatty's Avatar
I used Drake's seals on the rear quarter windows on my 40 two-many door; it was a wrestle to get them in the frames but in the end they fit well.
Hal Beatty is offline   Reply With Quote
