02-27-2012, 02:33 AM | #1 |
Modern tube shocks
Does anyone have a photo of the bracket used on the rear of the modern tube shock kit from Snyders? It attaches to the backing plate. Also, any idea on the length of the shock? I have the front shocks all but done but would like to run these since the shock balls where removed from the spring perches. Really don't want to by the whole kit this time......
02-27-2012, 07:36 AM | #2 |
Re: Modern tube shocks
I bought the whole kit for the roadster but only use the rears, the fronts were too stiff. Don't have pictures but the rears worked out well, ride well and are easy to mount with the supplied hardware. I ended up using the fronts on a woods machine doodlebug.
02-27-2012, 01:45 PM | #3 |
monroe # 31069
02-27-2012, 04:22 PM | #4 |
These look nearly identical to the Ken Davis shock kit that I installed a few months back. I'm very happy with it, but would make one recommendation.
The original nuts that secure the bolts through the backing plates on my '30 Coupe have a built-in spacer to fit into a recess. The nuts that came with my kit didn't, and the new bolts are a different thread, so you can't reuse the old nuts. I made some small spacers to compensate. If this is the case with the kit you have, I would strongly recommend that you take the time to get longer bolts the same thread as the originals, drill a cotter pin hole through them, and reused the original nuts. That being said, I'm very happy with my tubular shocks and would definitely do it again. If you just want the rears, I'm pretty sure that Ken will sell you a rear set only.
Style beats speed any day, and with a lot fewer tickets. |
02-27-2012, 04:47 PM | #5 | |
Cowtown A's |
02-27-2012, 08:01 PM | #6 |
02-27-2012, 08:02 PM | #7 |
kendavismodela.com
Cowtown A's |
02-27-2012, 08:15 PM | #8 |
Got it Logan.....THANKS!
07-05-2012, 02:47 AM | #9 |
And all this time I thought the passengers were the shock absorbers............
07-05-2012, 12:27 PM | #10 | |
BTW, I am very pleased with Ken's kit, have a little over 1,000 miles on it. Last edited by CarlG; 07-05-2012 at 01:08 PM. Reason: Add Picture |
07-05-2012, 01:36 PM | #11 |
Am I the only one that sees a problem with the angle of the shocks in regards to the movement of the axle?
Do these pivot some how? |
07-05-2012, 05:38 PM | #12 |
It may not be mechanically efficient but it isn't as bad as the angle on our town and country van and they work very well.
07-06-2012, 12:16 AM | #13 |
The rubber mounting donuts allow a few degrees of angle change in axle movement.
07-06-2012, 09:32 AM | #14 |
We have the older Ken Davis with the red shocks (happy) wonder what is softer the red or blue
07-06-2012, 10:10 AM | #15 |
My friend put tube shocks on his 29 Tudor, they were red when he bought then (Not a Ken Davis kit). My Ken Davis kit was blue. Both sets are now black, as they were painted before installation.
I really think that the black ones give the better ride! |
07-06-2012, 11:17 AM | #16 |
This is on a 31 Slant Windshield Sedan,Kit came from Sacramento Vintage
Any man who thinks he can be happy and prosperous by letting the Government take care of him, better take a closer look at the American Indian!" - Henry Ford |
07-06-2012, 12:07 PM | #17 | |
See now that looks like it actually works! How can they bolt a shock on at a pretty good angle, without a pivot point. I can't see two simple rubber mounts with a straight bolt giving enough movement. |
07-06-2012, 12:24 PM | #18 |
No You're not! I've been considering fabricating these brackets for a while. What is the minimum thickness the bracket can be? 1/4" ? 3/8 "?
Some use a verttical piece of angle iron and weld the tab after bending it. I'd like a better description of the top bracket and where it attaches. Terry |
07-06-2012, 07:33 PM | #19 | |
Which vendor did you get those bolts from? And are they the fine thread like the originals? Ken
07-06-2012, 07:44 PM | #20 |
